Remove coil springs 69
Old Jul 30, 2013 | 08:11 AM
Mikesfreetime's Avatar
Mikesfreetime
Default Remove coil springs 69
Im Removing the coil springs from my 69, is there a relatively inexpensive compressor anyone has used?
Old Jul 30, 2013 | 08:56 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Use at your own risk..
Corvette Spring Compressor on a Budget. . Ugly Tricks to the trade 1963-1982
Old Jul 30, 2013 | 02:41 PM
Rally68's Avatar
Rally68
If you have a small block, you don't need a spring compressor. I have done it both ways, and IMHO using a spring compressor is a major headache.
Support the car on jack stands or a lift, use a trolley jack to support the lower A arm, and pop the ball joint(s). Use a chain or rachet strap to keep the spring from popping out and bouncing across your garage while you let the A arm down and release the spring.
Reinstalling is easy, just align the spring in the pockets and use a stout bar clamp to hold the spring to the lower A arm while you raise it back up with the jack:
To each his own, but I never have liked wrestling compressed springs into place up under a car. This way, when the spring is compressed (or released), I'm standing off to the side only close enough to reach the jack handle.
Old Jul 30, 2013 | 02:50 PM
ddawson's Avatar
ddawson
I've never had a car that was as easy to replace the springs like my C3.
I have an outer and inner spring compressor. After reading the Willcox paper on it I realized I can use my inner compressor in the same way.
An inner spring compressor has two arms that grab the spring. Remove both arms and with two washers slide the threaded rod though the top shock hole.
Now take the threaded compressor arm and feed it though the bottom of the spring. Connect it to the spring and the threaded rod and compress away.
Old Jul 30, 2013 | 03:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Generic auto parts places often loan/rent spring compressors. Cost is usually minimal.
Old Jul 30, 2013 | 03:17 PM
540 vette's Avatar
540 vette
I use this spring compressor. But instead of using the top hooks I remove it and put it thru the shock hole in the frame. Then a couple of washers and a nut and pull up on the spring. Then I take the control arm down from the inside. I don't break the ball joint loose.
Old Jul 31, 2013 | 06:55 AM
Mikesfreetime
Well I was hanging around some older mechanics yesterday and one guy told me his method. Basically take everything loose with the exception of the shock, then let the preasure off the shock alowly and it slid right out. They all just laughed about needing specials tools and I must say it worked like a charm.
Old Jul 31, 2013 | 07:12 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
That's the tool I've used.
To Remove coil springs 69
