1974 Engine Wiring Harness
My questions is:
Is this easy to do? Parts are reasonably cheap from the forum's vendors...~$150.
Do any of the wires in the harness need to be connected behind the dash? I would really rather not open up that can of worms at this time.
I do have the AIM, but it is not immediately clear to me which wiring connections belong to the engine wiring harness versus other harnesses.
I appreciate any guidance and advice you can provide.
John
These two harnesses plug together at the firewall and connect to the main dash harness.
My mechanic replaced the starter for me and noted that the insulation was cracking enough to begin exposing wires. He said it was only a matter of time before I started having problems due to water and corrosion. He taped the wires at the starter as best he could, but recommended changing the harness to ensure reliability. We are primarily focused on reliabilitiy and drivability issues at this point...the other harnesses may in fact be equally tired, but probably will not leave me stranded.
The car has left my wife and I stranded twice in the last 90 days...she was not pleased...hence my focus on making the car reliable.
John
I replaced the engine harness on my 74, and it's not that bad of a job. I think it looks more intimidating than it really appears to be. Your best tool will be patience. The harness attaches to the back of the fuse panel, start there and try to keep it organized. All the wires that go to their respective components are the same color in the new harness as in the original. So there's no need for confusion. Just go slow, take your time, and for God's sake do one wire at a time and work your way from the back of the fuse panel across to the passenger side and end at the starter. I found it easiest that when you take a wire off or out of a component add the respective wire from the new harness.
As a side note, when you get over to the seatbelt interlock relay on the passenger side firewall, note if the relay is bypassed (jumped) in any way, because you'll get done and the car won't start.
Alex
Thanks again, John
Strip some of the cover back and check it. It's easy to cut out and replace a foot or so. Just crimp, solder and heat shrink and as good as new.
