Radio Delete
Old Aug 5, 2013 | 06:15 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Default Radio Delete
Anyone know what the factory with the antenna hole on a radio delete car? I have no need for music when there is a Chevy V8, so out it all goes, but I want to plug that hole.
Old Aug 5, 2013 | 07:03 PM
mrmagrath's Avatar
mrmagrath
I don't believe factory radio delete cars had aerial holes.
Old Aug 5, 2013 | 07:58 PM
gbvette62's Avatar
gbvette62
The factory didn't delete radios, because radios were optional. On a car ordered without a radio, it came through without an antenna or antenna hole. The ignition shielding (except the brackets), ground straps, and condensers; were left off also.
Old Aug 6, 2013 | 11:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by gbvette62
...The factory didn't delete radios, because radios were optional. On a car ordered without a radio, it came through without an antenna or antenna hole. The ignition shielding (except the brackets), ground straps, and condensers; were left off also...
Bingo. Radio Delete is a misnomer. I've seen pics of the undersides of rear surround panels showing a factory patch where the antenna hole was filled.
Go here: http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice for your 77. If a radio was ordered, it will be on the invoice.
Old Aug 6, 2013 | 12:31 PM
Mike Ward's Avatar
Mike Ward
There is a no charge radio delete option (RPO UL5) specified for some year C3s, so the term is not totally incorrect.
To Radio Delete
