Sudden Stop shutdown
Old Aug 6, 2013 | 02:42 PM
newbie2vette's Avatar
newbie2vette
Default Sudden Stop shutdown
Several months ago I had the 750 CFM holley re-built on my 1972 LT1, but not satisfied how the car ran with it. A buddy had a year old newer version installed that, at first it had a flat spot from the idle. I adjusted the accel pump, that took care of the problem. However, during my test drive if I get on the throttle and then stop quickly the car wants to die down to 3-500 rpm but picks back up.
Fuel delivery is not my strong point, hence looking for some help.
Old Aug 6, 2013 | 06:08 PM
TimAT's Avatar
TimAT
Check your float levels. If the rear one is a little high, it could slosh over and be flooding during a quick stop. Same for the front if it's a touch low- uncovering the jets and leaning it out.
After the engine has been running, shut it off and remove the sight plug from one end. Shake the car- gas should just barely creep over the threads. Repeat for the other end. Adjust until the fuel level is right at the bottom of the sight plug.
Old Aug 6, 2013 | 07:51 PM
newbie2vette
Thank you! I remove the rear sight (clear plastic), a lot of fuel ran out from the hole indicating the level is high. I am reading the adjustment procedure, since the level is initially high. Which direction should I turn the adjustment nut to have it set at a low level? I have an electric pump, can adjust slowly to the proper level.
I found a video by holley, but the narrator was a speed talker. but I did catch, if the fuel level is too low the float should be raised. I guess I am bouncing my findings in here for verification.
Old Aug 7, 2013 | 01:27 AM
TimAT's Avatar
TimAT
Put a wrench on the nut, and a large screwdriver in the slot. It won't take much to break the nut loose. When it's loose, hold the screw and turn the nut clockwise, then tighten the screw down on top of it. Same to raise the level, but turn the nut counter clockwise. If you have clear sight plugs, the fuel level should be right at the bottom.
Old Aug 7, 2013 | 07:22 PM
newbie2vette
I would like to thank you for your assistance, making the adjustment today gave me a better understanding. I've always heard adjusting Holley carbs are very easy, guiding me through this adjustment definitely made a believer out of me.
To Sudden Stop shutdown
