what is draining battery
Old Aug 7, 2013 | 11:48 PM
runningstart's Avatar
runningstart
Default what is draining battery
Hello, new to the forum. Name is Joe. Recently purchased 82 was non-running at time of purchase 2 weeks ago.
New battery was installed approx 1 week prior to purchase. Replaced fuel pump with new '85 pump after getting the car home and she fired up and ran well and has been started a couple of times during the week.
Tonight I went out to start the car and the starter solenoid clicked but no cranking. There was enough juice for the interior lights and dash. I've had it on a charger for a few hours and now she cranks but still no start. I figure the battery needs a few more hours charging.
So I can't find anything drawing current, all lights, radio are off. What could be draining the battery?
Joe
Old Aug 8, 2013 | 08:30 AM
68L79's Avatar
68L79
1. get a battery cut off and when you are thru with the car....cut the power...I do that even though no problem.
2. Take one cable off the battery and Remove one fuse at at a time and touch the removed cable to the battery in low light....if you see a spark, that circuit is okay, replace that fuse and to the next one. When you do not see a spark with a chosen fuse, that is your problem circuit...then work on finding a short according to whats run by that circuit...
You will only get a spark when something is drawing power from the battery.
Old Aug 8, 2013 | 08:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the courtesy light delay timer. They're notorious for slow battery drains.
Old Aug 8, 2013 | 09:53 AM
Crafty12's Avatar
Crafty12
Roger put together and excellent step by step thread that resurfaced recently. It helped me.
http://forums.corvetteforum.com/c3-g...with-pics.html
Old Aug 8, 2013 | 09:59 AM
Arkyvette's Avatar
Arkyvette
Do your 82 a favor and do not cut off the power or unhook the battery a lot. The ecm does not like that. It forgets idle settings that take several miles over 30mph to relearn. They are also very sensitive to spikes and seem to fry quite easily, to the point that I would not jump start my 82. If you do use a cutoff, I would bypass the fused wire in the battery compartment so that your ecm can stay hot when the rest of the car is disconnected.
Old Aug 8, 2013 | 10:13 AM
mwm1993's Avatar
mwm1993
You could use an ammeter connected at the battery to see how much current is being drawn. Tape the door switch so the lights stay off as if the door is closed and pull each fuse one by one until the current draw drops and that's your bad circuit
Old Aug 8, 2013 | 02:16 PM
68L79's Avatar
68L79
Forgot about the newer ones having a computer..or something like a computer....once a corvette gets past a 72....never looked at one or read about one or have an ounce of interest in one....my experience is completely redoing a 51 ford sedan, 55 ford f100, and my 68 corvette...and presently under complete re-building is my 1949 chevy fleetline....built 283, 700R, frenched 59 caddys, frenched headlight, air, MII front end, p trunk, pw, pb, tilt, one piece windshield, california one piece bumpers, etc.
Old Aug 8, 2013 | 10:24 PM
runningstart
Default Problem solved!
Thanks for all of the excellent advice. I'm particularly grateful for the step by step procedure written by Roger and linked by Crafty12. However, I believe the problem is solved without in depth troubleshooting.
I discovered that the glove box door doesn't latch and the PO had wired it closed but not completely closed so that the glove box light stayed ON. I've placed a piece of cardboard there to temporarily turn off the light, and now have the car on the charger once again.
To what is draining battery
