Shifter boot
Old Aug 11, 2013 | 02:27 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default Shifter boot
Hey guys,
I want to change the shifter boot in the car but I can't figure out how to get the plate up. (plate with the 1-4 gears and R diagram) I think it is bolted down but I cant get at them because of the rubber armrest \ parking break cover. Some instruction would be great.
I have an AIM but I couldn't find the section that deals with this.
Thanks.
Old Aug 11, 2013 | 02:48 PM
Bagpype's Avatar
Bagpype
Are you talking about the boot itself or the whole center plate? Also, what year is your corvette?
Old Aug 11, 2013 | 02:53 PM
donnie1956's Avatar
donnie1956
You will need to remove the console sides panels. That means taking the seats out on my 78. Then you can get to the screws from the bottom.
Old Aug 11, 2013 | 03:04 PM
~Stingray's Avatar
~Stingray
I have 1980. I need to replace the boot. So whatever that entails. In my mustang, I can get the whole center console up in 5min. But this doesn't look to be that easy.
Old Aug 11, 2013 | 08:12 PM
Bagpype's Avatar
Bagpype
It's easy. As donnie says, remove both carpeted side panels and that will give you access to the screws to remove the console.
Old Aug 11, 2013 | 08:57 PM
qwank's Avatar
qwank
you can probably change the boot by just taking out the drivers seat and drivers side panel off. the 4 bolts tht hold the boot in come out from the top. then with the side panel off, you can finagle the boot on and off after you remove the shift ****
Old Aug 12, 2013 | 09:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ~Stingray
...I have an AIM but I couldn't find the section that deals with this....
Interior.
Old Aug 12, 2013 | 04:18 PM
~Stingray's Avatar
~Stingray
Hey Mike,
This is what my contents page looks like...
Unless there is a hidden index somewhere, I don't see "Interior". And I wasn't about to flip through every page until I found it.
Old Aug 12, 2013 | 04:20 PM
~Stingray's Avatar
~Stingray
I cannot believe the engineers thought it was a good idea to design the car so that you have to remove the seats from the car in order to get at anything in the center console.
Quick question, I was able to drop the boot through the hole of the original boot, it looks like it will really stretch the boot when I am going through the gears. Should it be that tight?
Thanks.
Old Aug 12, 2013 | 04:37 PM
LS4 PILOT's Avatar
LS4 PILOT
I replaced the inter rubber shift boot and the leather outer on my car over two decades ago, when these parts were still available over the parts counter... it was one of the few easy things I replaced on any corvette...Lol just a bunch of screws really . The GM factory leather boot was of much higher quality , thicker material than repro replacements I 've seen. it's easy, if I could do,it with zero instructions anybody could
it is possible as with most repro parts they didn't get the size , material or construction right.
maybe a NoS one could be had.?
Old Aug 12, 2013 | 04:52 PM
qwank's Avatar
qwank
I agree the repop boots aren't that great, I custom made a boot from a CTS-V boot I had laying around
Old Aug 12, 2013 | 07:57 PM
~Stingray's Avatar
~Stingray
I was gonna say, yours looks pretty good.
My screws don't even go in that evenly. They are seated at an angle.
To Shifter boot
