Repainting Interior Trim Plates
Old Aug 15, 2013 | 02:36 PM
Joe Buck's Avatar
Joe Buck
Default Repainting Interior Trim Plates
Anybody have any luck and/suggestions on finding a well matched silver paint for touching-up the chrome outline around the instrument cluster, shifter plates?
Seem to fade fairly quickly, not worth purchasing a new one.
Old Aug 15, 2013 | 03:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Joe Buck
...Anybody have any luck and/suggestions on finding a well matched silver paint for touching-up the chrome outline around the instrument cluster, shifter plates?...
Not here. Chrome is a plating, not a paint. The paints advertised as chrome, aren't. All you get is a bright silver.
Old Aug 15, 2013 | 07:12 PM
Joe Buck's Avatar
Joe Buck
Wasn't looking for semantics, but thanks???
Old Aug 15, 2013 | 08:40 PM
gbvette62's Avatar
gbvette62
You didn't bother to include a year, but I'm guessing that your referring to the "chrome" trim, around the edges of the plastic console and gauge cluster, of 77-82 dashes? There is something you can try, that I've had some success with.
Hobby shops sell sheets of silver foil, called "Bare Metal Foil". It was originally used by model plane builders, to replicate aluminum fuselages, but model car builders use it also, to duplicate chrome trim.
You lay the Bare Metal Foil, on the surface that you want to transfer it too, rub it down, and trim the excess with a hobby knife. It actually works pretty good, and looks like chrome, or chrome-ish anyway.
Old Aug 15, 2013 | 10:09 PM
Joe Buck's Avatar
Joe Buck
Exactly what I was looking for. Will immediately look into it.
THANK YOU GENEROUS HOST!!!
Old Aug 16, 2013 | 01:14 AM
mrmagrath's Avatar
mrmagrath
I would suggest putting some clear over the whole shebang, as that lead foil is very delicate. You can get adhesive for aluminium foil from hobby shops that you brush on. Aluminium would be a bit sturdier than lead. I build a lot of models!
Old Aug 16, 2013 | 11:08 AM
Easy Mike's Avatar
Easy Mike
...Wasn't looking for semantics...
You asked for paint. My point is only that you cannot duplicate chrome plating with a paint.
To Repainting Interior Trim Plates
