'77 L82 Value
Old Aug 19, 2013 | 10:50 PM
kjb13's Avatar
kjb13
Default '77 L82 Value
Is there anyplace other than NADA to look up the value of a '77 L82, or any other classic car for that matter?
Rebuilt engine and auto trans, about 80,000 miles, new interior, paint maybe a 7 or 8 out of 10.
Old Aug 19, 2013 | 11:02 PM
kjb13's Avatar
kjb13
This is the L82 in question
Old Aug 19, 2013 | 11:23 PM
jnealg's Avatar
jnealg
http://www.hemmings.com/priceguide/
Old Aug 19, 2013 | 11:40 PM
kjb13's Avatar
kjb13
Originally Posted by jnealg
Thanks for the info.
Old Aug 20, 2013 | 09:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What is the seller asking?
Old Aug 22, 2013 | 08:40 PM
kjb13's Avatar
kjb13
Up for auction this saturday.
Old Aug 22, 2013 | 09:44 PM
MakoJoe's Avatar
MakoJoe
Nice looking car hope you win it :o)
Give the car a really good look over and look at the suspension real well to see how much work it needs. Pull the steering wheel for play. It may need some work but if you can get it between $9000 and $12000 you will do well. Think about how much more you will have to put into it. Suspension rebuild will cost about $3000.00 and it is higher mileage at 80,000 miles so expect to put money into after you buy it.
I purchased a 1977 L48 this spring after 3 monhs of looking for Corvettes between the year of 1971 and 1978 than found a 1977 L48 with 43,260 at time of purchase for $9000.00 and knew going into the car I would have to drop about $4000 into it to fix the suspension problems and anything else I encountered. I am about $2500 into repairs at this point and still need to perform more work on it. When I am done it will be in excellent condition for it's age and mostly all original.
Old Aug 23, 2013 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by kjb13
...Up for auction this saturday...
Sorry, but what the car might actually be worth may not mean much at an auction. All it takes is one bidder who is Hell bent on owning the car for the bidding to go way over the top.
Good luck.
Old Aug 24, 2013 | 11:57 PM
kjb13's Avatar
kjb13
Top bid was $5,500. The seller had a reserve at $12,000.
To '77 L82 Value
