explain why LED conversion loses backup light
Old Aug 20, 2013 | 12:10 PM
runningstart's Avatar
runningstart
Default explain why LED conversion loses backup light
Forgive me I've read the old posts on LED conversions and haven't found an answer. So can someone explain why a led conversion has to lose the backup light.
Old Aug 20, 2013 | 12:18 PM
Marty913's Avatar
Marty913
I would also like to know the answer. I know there are other solutions like license plate LED backups so what is it about the normal backup lenses that is different?
Old Aug 20, 2013 | 01:03 PM
Trae1976's Avatar
Trae1976
I'm not sure what conversion you're referring to, but I don't know why the backup lenses & bulbs would have to be replaced.
I wanted to keep the stock look on mine, so I created my own.
Old Aug 20, 2013 | 03:55 PM
runningstart
http://www.corvettemods.com/1968-198...ts_p_7532.html
Thats one example. There are other direct swaps available on that famous auction site. I don't want to fabricate my own because I'll butcher it up I'm sure and I have to get new taillights anyway. I just figured some vendor would have a direct swap kit that keeps the backup lights. I haven't found one so I'm curious why they can't do it without sacrificing the backups.
Old Aug 20, 2013 | 04:03 PM
ddawson's Avatar
ddawson
LED is just a light. You could use LED bulbs.
I'm a little confused on what you are asking about.
1157, From Superbright
1156 Backup light.
Old Aug 20, 2013 | 04:12 PM
Trae1976's Avatar
Trae1976
Thats one example. There are other direct swaps available on ebay. I don't want to fabricate my own because I'll butcher it up I'm sure and I have to get new taillights anyway. I just figured some vendor would have a direct swap kit that keeps the backup lights. I haven't found one so I'm curious why they can't do it without sacrificing the backups.
Ah, I thought you meant a conversion requires eliminating the backups. You could opt to change only the outers and leave the backups as-is, but I know that's not a desirable solution.
I couldn't find a readily available solution either, this is why I built my own.
Old Aug 20, 2013 | 05:00 PM
runningstart
1156 Backup light.
Ok, so if I keep the stock housings then 1157(6)-style LED lights can be installed directly in place of the stock incandescents?
Old Aug 20, 2013 | 06:41 PM
ddawson's Avatar
ddawson
Yes, but the issue is will it be enough light.
You will have to experiment with them as there are many options.
I have some multi SMD in other car for the dash lights and it worked great.
See this thread. http://forums.corvetteforum.com/c3-g...led-halos.html
He used the 3w single point 1157 LED from superbright but made a change for the running light. Seems bright enough to me in the video with the flashers on.
Old Aug 20, 2013 | 10:14 PM
runningstart
Thanks for that ddawson. Yes I've read that thread. I might go ahead and experiment with the current taillight housings, as I said they need to be replaced anyway but at over $200 for a set I was considering going with a plug-n-play LED replacement with new housings.
However, the individual LEDs are cheap and I found some on the famous auction site that are sold as taillight/brake light/turn/backup lights so maybe they are bright enough.
Maybe even experiment with halos.
To explain why LED conversion loses backup light
