need help
Old Aug 25, 2013 | 09:10 PM
john53's Avatar
john53
Default need help
I have a 1976 stingray corvette. I have replaced both flashers under the dash and the one behind the passenger seat. My 4 ways do work ,so doesn't my brake lights and my reverse lights, however my turn signals do not work also my front head lights do not work. The front head lights do pop up but they don't turn on any help would be greatly appreciated. Thank you
Old Aug 25, 2013 | 09:15 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Not sure if i can help with the front, but the flasher behind the passenger seat is for the factory alarm.
Old Aug 25, 2013 | 09:38 PM
john53's Avatar
john53
Hey any advice is help buddy, now you said that the one behind the seat is for the factory alarm, im not quit sure what the factory alarm is.?
Old Aug 25, 2013 | 09:44 PM
sweeet76's Avatar
sweeet76
Are you saying your back up and brake lights do work.
Old Aug 25, 2013 | 09:59 PM
john53's Avatar
john53
Yes they do.
Old Aug 25, 2013 | 10:20 PM
carjack007's Avatar
carjack007
Hi John,
One possibility for your blinkers not working would be the turn signal switch located in the steering column. Did they just stop working both left and right?
Regards,
Bob
Old Aug 25, 2013 | 10:29 PM
john53's Avatar
john53
Thank you for the reply Bob. As a matter of fact I just bought the car. When I got it I had to replace the flashers to get the four ways to work. But that is as fare as I got I really wanted other opinions befor I want further. I checked all the bulbs and there good. Thank you for the help.
Old Aug 28, 2013 | 10:48 AM
74Ken's Avatar
74Ken
So that't what that is for, the PO removed the alarm key on the side when he fiberglassed the front nose on my 74.
I noticed there is a flasher behind the passenger side dash and one near the fuse panel.
Not sure if this helps.
Old Sep 3, 2013 | 09:15 PM
john53's Avatar
john53
Thank you for the help. It helped me out. I found out that the light problem was due to the moisture getting into the switch. But I will see if there is a flasher under neeth the pasenger side dash thank you 74ken.
Old Sep 3, 2013 | 09:39 PM
john53's Avatar
john53
Okay wow soo thank you. The flasher on the passengers side under neath the dash is for the blinkers.. thanks every one.
To need help
