78 vette trans
Old Aug 26, 2013 | 11:15 AM
osterro01's Avatar
osterro01
Default 78 vette trans
I'm looking ata '78 vette w/ auto trans. Fluid on floor and trans hard to shift from park to drive. Any idea of problem?
Old Aug 26, 2013 | 11:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the tranny fluid level. Sounds like it's leaking and probably low.
Old Aug 26, 2013 | 12:33 PM
donnie1956's Avatar
donnie1956
Leak in front or center of car? Came with oil cooler attached to front of radiator. Probably low on fluid.
Old Aug 27, 2013 | 08:59 AM
osterro01's Avatar
osterro01
leak appears in center. Would the most common trans leak be from the trans pan gasget? Is there a drain plug for the auto trans?
Old Aug 27, 2013 | 10:14 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by osterro01
...Is there a drain plug for the auto trans?...
No.
Old Aug 27, 2013 | 10:25 AM
donnie1956's Avatar
donnie1956
Wipe the pan off and go for a short drive. Pan gasket can easily be replaced. Could be the front seal or rear. Thats' bad news as you will have to pull tranny to fix. Or just keep the fluid full and keep a pan under the car when parked.
Old Aug 27, 2013 | 11:56 AM
osterro01's Avatar
osterro01
This car has only 19K miles on it. It hasn't been driven often. What are the odds that the main seals would go bad within 19K miles?
Old Aug 27, 2013 | 12:24 PM
oldschoolvette's Avatar
oldschoolvette
very good. they get dry and the when you do drive they are not lubed and wear.
Old Aug 27, 2013 | 12:46 PM
osterro01's Avatar
osterro01
thanks to all who have responded to my questions... very helpful
To 78 vette trans
