I have been sorting things out on my 1978 L48 anniversary with cruise car for the past 10 months . Had the brakes checked today and they were good with 70 percent left . Thats the good news .
I bought a lower speedo cable thinking that the speedo guage was bouncing because of that . Turns out my mechanic tested both cables (upper and lower) and they are fine . He seems to think its where the speedo cables connect to . Looks like the cruise control box . From what I've seen here this doesn't seem likely . Or am I wrong . If I am wrong what's the best route to go . Thanks in advance .
When my car did this, it was the lower cable. I ended up putting in one long cable by-passing the cruise control box.
I could be wrong, but bet it's the lower cable. As the cruise control box wares, it will put more an more tension on the lower cable until it eventually breaks.
The cruise control box is the most common area that causes a bouncing speed reading provided the cables are good. Since the cables are good I would remove the control unit. If you are ok with disassembly of the unit you will find a good cleaning on the discs inside will improve the speedo reading. It usually doesn't fix it for a long time, but will show you where the problem is.
On another note . When I drove the car home last night I let it out somewhat and when I did this the speedo started working . I noticed that after a good run it did get better . It's not fixed but worked a lot better for a little bit .
So , if I bypass the cruise control does this mean I remove the upper cable and go right through the firewall to the cluster ? Sounds like I also need a longer cable . How long ? I think the lower is 49 inches .
Just replace the cruise control module. Remove it and cleanup the inside of the old unit and you will notice a big change until you get the new unit this would be a similar cost to getting a longer cable and your cruise control will still work.
Ok , sounds like a plan . Now to figure out where to get the unit from . I'm gonna start looking .
