Easy C3 Hood Replacement Procedure
It's like it was almost designed for this!
Use rags on the edges so that the tabs don't damage the hood.
You could push the hood all the way down, with one finger!
My shop partner, John, easily mounting the hood hinges. Nobody is struggling holding up the hood, while trying to start the bolts on the loose hinges, it was so easy!
Hood is done, just need minor adjustments and you're good to go.
pull engines, duh!
pick up and mount outboard motors
third strong arm to pick up whatever
and finally to hang and clean deer, LOL's!
