Death by Valve Cover
I (or more correclty my neighbor) just solved a 3 week mystery. I got a new corvette about a month ago, had it for a few days drove it to the dmv to get registered, idled a little fast but not bad.
Then I changed valve covers to this set that looked great. they were supposed to be original for chevy small block.
after that the car would not run, it was only hitting on a few cylinders. the guy before me had put on a holley 770 double pumper and edelbrock air flow manifold. I had to make an makeshift air cleaner because of lack of clearance from these high performance pieces.
after a week of trouble shooting, I had the original stock Rodchester carb reworked, and put back the original manifold. still did not work, I had guys setting the timing all over the place, still did not work. I took off the valve cover to see what was going on it worked, put it back did not work.
apparently the cover was holding the valves open so no compression. Who would have thought that.
has anyone heard of this problem?
Vet69
Stock,stamped steel rockers?
With only 4 posts so far, I won't jump to conclusions. For your car's sake, I hope that when you run into any interference when disassembling or assembling automotive parts and pieces, that there may be a reason for that. Putting the big arm on stuff isn't always the answer. That's a nice looking '69 you have.
I wish you well and please feel free to ask the CF about any future issue if something like this happens again. One of us may have already been there and done that.
Good luck.
What did you do for a PCV? Do you have a picture of your engine bay with it all assembled?
