Oil Question
Old Sep 2, 2013 | 01:38 PM
1978vett's Avatar
1978vett
Default Oil Question
I'm getting ready to change the oil for the first time in my 78, I am looking for advise on what kind and what weight to use.. It is a 78 with L82 motor, auto trans... with headers,,42000 miles .. It will be driven in warm weather mostly.. Thanks for your help ..
Old Sep 2, 2013 | 01:44 PM
briankeery's Avatar
briankeery
Oh oh, here we go.........Valvoline VR-1
Old Sep 2, 2013 | 01:58 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
do your homework and read the stickie in the c3 tech and performance unless you wanna start an argument.
Old Sep 2, 2013 | 02:28 PM
1978vett's Avatar
1978vett
excuse me for asking....
Old Sep 2, 2013 | 02:42 PM
kenpofan's Avatar
kenpofan
IMHO Classic Car oil with good Zinc levels..
In the past this has been a heated debate issue.
Old Sep 2, 2013 | 02:55 PM
1978vett's Avatar
1978vett
Thanks for your reply,, I wasn't trying to cause any drama,, I'm new to Corvettes and am just trying to get answers from the people who have owned them for a while..
Old Sep 2, 2013 | 04:13 PM
kenpofan's Avatar
kenpofan
We have experts on everything here , the problem is they for the most part can't agree on oil types or e-10 gas .
FWIW
I like this oil. http://www.castrol.com/castrol/gener...tentId=7032644
easily available and high zinc.
Old Sep 2, 2013 | 05:34 PM
MelWff's Avatar
MelWff
this is the highly debated thread, I use 10W30 Valvoline VR1 but only drive about 1k per year.
http://forums.corvetteforum.com/c3-t...test-data.html
Old Sep 2, 2013 | 08:57 PM
Lupigiato's Avatar
Lupigiato
I have a 68 rebuilt, high performance engine setup. I also have a stock 73 and use Valvoline VR1 20W-50 in both. As Brian said, everyone has a different and emotional, loyal and strong preference to their oils. If you search and read the threads on this topic, you will not come away with one brand and viscosity. I chose my oil based on a Corvette experts opinion and that was good enough for me and have 0 complaints. I tried synthetic oil once and will never go back, as it leaked all over the place. I like a thicker oil in these old cars.
Old Sep 2, 2013 | 09:22 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
No need to play engineer if its stock, just go with what GM recommended.
Old Sep 2, 2013 | 09:30 PM
briankeery's Avatar
briankeery
GM recommended everything from 5w30 to 20w50. That's not as important as realizing that zinc levels have changed since your '78 was built. Therefore the arguement that develops is how much zinc you need in your oil for your original flat tappet cam engine. As mentioned, read the sticky if you like and maybe that will help you understand people's choices.
Old Sep 8, 2013 | 05:29 PM
C6DuffMan's Avatar
C6DuffMan
I'm using 15W50 Mobil 1 in my 71 454 and it's starting to leak. It's leaking at the back of the oil pan and out the valve covers.
I'm going to try the Valvoline VR-1.
To Oil Question
