Troubleshooting interior lights
Old Sep 7, 2013 | 05:12 PM
BDoc's Avatar
BDoc
Default Troubleshooting interior lights
So I'm tackling the interior/instrument lights not coming on this weekend. I removed the entire dash and have done some troubleshooting. Here's what I've done so far:
- Hooked up temporary 12v+ and temporary ground with alligator clips - varios test lights come on one at a time while testing
- Removed lights from console and hooked up temporary ground with alligator clips - lights do not come on when headlights turned on
- Removed lights from console, hooked up temporary ground with alligator clips and manually fed 12v+ into disconnected headlight switch harness. Lights do not come on
- Manually fed 12v+ on to each end of the fuses in the fuse block to rule out a fuse block issue, lights do not come on
So... I can only surmise that there is some kind of disconnect in between the headlight switch and the bulbs that is opening the circuit. Anyone got any tips for me?
Old Sep 7, 2013 | 07:23 PM
gr8t73's Avatar
gr8t73
BDoc I had an issue with nonfunctional interior lights also. I replaced all the interior bulbs which was a major PITA but still no lights. Next I checked all the fuses & interior grounds & still no lights. While working on the lights I was rotating the headlight switch for dimming the interior lights & noticed the interior lights would flicker. I bought a good quality replacement light switch not the Chinese made switch from Doc Rebuild installed it & the lights work great. Turns out the rheostat in the old original switch was bad. May or may not be your problem but worth checking.
Old Sep 7, 2013 | 08:08 PM
BDoc's Avatar
BDoc
Thanks for the tip gr8t73.. I was thinking I ruled that out by applying voltage to harness connector on the other side of the switch, but who knows...
Old Sep 8, 2013 | 09:18 AM
BDoc's Avatar
BDoc
Nobody knows? Dang. Well maybe it's a shorted out wire in the harness... will check that this morning.
To Troubleshooting interior lights
