Seat Belt replacement question
Old Sep 7, 2013 | 10:59 PM
Sogo's Avatar
Sogo
Default Seat Belt replacement question
I had a friend pick up retro belts from Mid America for my C3 while he was at Carlise. While removing the original belt, I noticed the shouldered bolt is much larger in diameter than the opening in the replacement belt. After a search online, it looks as though a common 12/20 bolt is used. Is this a common replacement? Am I correct to say that the shouldered bolt is necessary to allow the seat belt to maneuver?
Old Sep 8, 2013 | 10:06 AM
71scgc's Avatar
71scgc
I used belts from MAM in my '71. I put the shouldered bolts back in. The supplied bolts from MAM were too long.
Carter
