Another...what is this?....
Old Sep 13, 2013 | 05:15 PM
LannyL81's Avatar
LannyL81
Default Another...what is this?....
In the picture below, which is from an '81 there is something on the parking brake cable up by the transmission, lite gray in color that I have not seen before, it is not on my '81 and I have no idea what it is....anyone know?
Old Sep 13, 2013 | 05:19 PM
tokim's Avatar
tokim
It appears to be a cable adjuster.
It has a hook inside that grabs the cable, as you tighten it up, it takes the slack out of the cable.
Someone has added it, not original.
Old Sep 13, 2013 | 05:36 PM
my 76 ray's Avatar
my 76 ray
One word comes to mind ... Bubba.
Old Sep 13, 2013 | 05:43 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Bubba also appears to have forgotten your catalytic converter
Old Sep 13, 2013 | 06:37 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Sep 13, 2013 | 06:49 PM
TimAT's Avatar
TimAT
IT takes up extra length in the parking brake cable- I've seen them used when the inline adjuster is frozen or the cable is too long for whatever reason. Bubba fix. Use that instead of fixing the real problem.
Old Sep 13, 2013 | 07:35 PM
maverickmk's Avatar
maverickmk
LOL, I thought the exact same thing when I saw the picture
Old Sep 14, 2013 | 12:55 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Why would this be a bad fix? Instead of replacing and rewiring, fix what you have. How would this cause future problems besides maybe down the road needing to replace the cable that you would have had to do anyway?
Old Sep 14, 2013 | 01:28 AM
Arkyvette's Avatar
Arkyvette
You people don't know bubba....bubba would wrap that cable around a bolt a few times and screw a nut on it. That device is NOT bubba
Old Sep 14, 2013 | 02:07 AM
razman's Avatar
razman
Old Sep 14, 2013 | 07:48 AM
tokim's Avatar
tokim
Because, the reason someone did this, is the cable has stretched, and apparently the adjustment is rusted, therefore not allowing it to be adjusted by the intended procedure. A bandaid.
That added on adjuster may also bang against the underside of the car, making noise, and scratching up the underside.
If you are going to devote time to a repair, do it right the first time.
The cable should be replaced, it has weakened.
Old Sep 14, 2013 | 08:25 AM
my 76 ray's Avatar
my 76 ray
OK, that's Bubba with an engineering degree.
Old Sep 14, 2013 | 08:49 AM
dtamustang's Avatar
dtamustang
not everyone has unlimited time and money to throw at their cars , as long as it doesn't bang around its a perfectly fine fix. at some point the real problem will need to be corrected , but if you are more interested in driving than fixing its a good way to go.
Old Sep 14, 2013 | 09:03 AM
LannyL81's Avatar
LannyL81
First off....this is NOT my car...just wanted to be clear on that one.
Anyways, when I got my car it had a Bubba cable fix....Bubba had welded a small socket to the original cable adjuster in order to give it additional range or length...to take the slack out of the cable.
Long ago I replaced all of the parking brake parts. I think I still have that Bubba fix someplace.
Thanks for the responses.....I thought it was some type of length adjuster....just have never seen this on a car before now.
Old Sep 14, 2013 | 01:13 PM
razman's Avatar
razman
the "bubba with the engineering degree fix" doesn't look like an immediate problem to me.....let me ask this: how often is the emergency brake used or needed??? on an automatic car....almost Never. maybe a little more frequently on a manual ride.
To Another...what is this?....
