Spark Knock
Are you using a digital or dial timing light or standard light with timing tape or marks on balancer?
http://www.summitracing.com/parts/mr...make/chevrolet
If you've already got 4 degrees less advance than stock, it's likely not timing or it's not really knocking (detonation) that you're hearing.
Diagnosing and replacing a faulty EGR valve with a vacuum leak. - YouTube
If you are experiencing detonation at light throttle and not at WOT then I would suspect that the vacuum advance is the culprit. If you did not have detonation before taking it to the shop these guys may have actually advanced your initial timing and not retarded it.
We can retard your timing very simply by unplugging the vacuum advance can. This will not fix your problem it will only be used to help diagnose it and to see if your are in fact having detonation problems.
I am assuming that your mechanical experience is limited. If I am wrong let me know and we can move along more quickly. I don't want to insult you just trying to help if I can.
In this picture you see grey cap with wires coming out, that is the distributor cap. It is mounted on the distributor. Coming out the front of the distributor you'll see a silver conical can with a large hex shape on the end. This is your vacuum advance can. Yours may look slightly different but it should be close to this.
It also has a black hose connected to it that runs to the carburetor. To access this area you may need to take off your air cleaner assembly.
[IMG]
[/IMG]I want you to disconnect the black hose from the silver can and plug the hose with a bolt or golf tee or something that will make a seal and not fall out. Don't worry about the can and it's hole, it will be fine.
Now put your air cleaner assembly back on. Go take the car for a drive. It will not run as well and may seem gutless or have a hard time idling but don't worry about that.
What you are listening for is the absence of the rattling detonation sound that you have been hearing. If it is gone then your timing is too advanced. If not then it may be something else your hearing.
Then try stomping the throttle wide open briefly, I'm not saying go fast this can be done in first gear or from a stop. If you hear the detonation start let off the throttle immediately.
Like I said If I'm being too simplistic let me know.
[IMG]
So you don't want to run for any longer than necessary in this condition. If you can't stay within a few minutes of your place then locate the items I pointed out and make the changes once you get somewhere where you can test it, and after testing it change it back to the normal condition to drive home.
The guys who did your timing may have inadvertantly advanced your timing instead of setting it correctly. Based on this assumption your can either take it back to them and see if they will fix it correctly or you can tune it by ear as I will explain. This procedure is far from ideal or accurate but it can get your detonation to stop. Best plan is to get it fixed or learn how to fix it yourself. Get some books on tuning chevy 350's or get on line and do a lot of searches to find out how.
So to fix this for now what we can do is loosen the distributor hold down bolt and rotate the distributor clockwise. You want to do this about 1/8 inch at a time. Use the connection that the vacuum hose connects to on the vacuum can to gauge the distance you are rotating the distributor.
So loosen the nut which is down below the vac advance can where the distributor goes into the block just enough to rotate the distributor.
This will take a 9/16" end wrench. At least on mine it is. Could be 5/8". Once you got it loosened a little bit get a ruler and set it up so you can measure the distance your going to rotate it using the connection of the vacuum can to do so. Move it by pressing on the vac can rotating it towards the firewall of the car or in a clockwise direction.
Tighten the hold down bolt and test drive. During these drives you will have the vacuum hose connected to the vacuum can unlike your previous drive.
Listen for the detonation. If still there repeat the procedure again. Move it 1/8 inch, and remember to tighten the hold down bolt each time very important!
Repeat this procedure until the detonation is no longer heard. You will then have a roughly timed engine that at least will not destroy itself.
When all done you may then adjust the idle to something that works well.
As you go along you'll notice that your idle speed will get lower. This is correct, as you retard the timing idle speed reduces as you advance the timing idle speed increases.
So note your idle speed now when the engine is fully warmed up. Write it down. If you loose track or accidentally bump the distributor and don't know where it's at you can get back to where it started by turning it in the correct direction to get back the same idle you had before.
In this picture my finger is over the distributor hold down bolt. That hole next to it is where the distributor goes into the block.
[IMG]
[/IMG]
If you didn't have detonation before you took it in but did after you got it back, then very likely related to what they changed or managed to mess up for you. EGR is really easy to take off two bolts. Make sure not all carboned up and vacuum diaphram works that's about it.
