Interior lights with door switch
Old Sep 17, 2013 | 01:56 PM
kayak5728's Avatar
kayak5728
5th Gear
Default Interior lights with door switch
1979 Interior lights work by manually turning interior light switch but don't work with the door switches. If one switch is bad will it stop lights from going on or would both switches have to be bad. Or is there something else that would prevent lights from coming on when door is open. HELP
Old Sep 17, 2013 | 03:29 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
79s might have a delay timer for the courtesy lights. If it fails, you could lose the cabin lights.
Old Sep 17, 2013 | 03:34 PM
briankeery's Avatar
briankeery
Thinking along Mike's idea; if you pull out the glove box compartment, behind it you should see a small plastic orange box attached to a connector. This is your light delay timer. Remove this box from the connector, and jumper the two white wires together with a piece of wire, paper clip etc. Once done try opening and closing the doors and see if your interior lights come on. Good luck.
To Interior lights with door switch
