Three... two... one... lift off!
#464
SuperBuickGuy (06-16-2019)
#465
I have also been working on the underside of the t-tops, with VPA. I won't put the front and side edge trims back.
#466
Clap for the clip
One more step behind me
Prepped the rear clip area behind the t-tops with VPA. I want to shoot some epoxy and slick sand before the end of the summer!
I mounted the plates to test fit the t-tops.
#467
The T between The Tops
Then came time to adjust the gap around the t-tops.
My fake weatherstripping:
Squeeze the middle, build up the rear with VPA, and sand for a regular gap:
The resulting T:
The resulting T:
caskiguy (07-13-2019)
#472
Passenger side mirror
Next will be the passenger side holes in a perfectly virgin door:
I'm so excited to drill more holes into the body:
(pre-shower selfie)
Thanks for taking a peek!
(pre-shower selfie)
#474
How thick did you have to build up the VPA along the driver's side of your hood? My stock hood looks like it's about 1/8" low in one area on the driver's side but I'm unsure if that's too much to correct with just VPA. I can't correct it with the rubber blocks without the corner near the windshield being up too high.
#475
Indeed, but I think I'll get my youth color back once it's drivable again.
Both the driver side hood and passenger side clip are 1/8". Many will say that's too much, but I'm more comfortable applying VPA than mat and resin. Maybe time will tell us if it was a bad decision.
#476
Looking on the right side
Passenger door butchering? Checked.
I will get Low-Profile Socket Head Screws from McMaster to attach the sport mirror.
Oh, look, boxes from England! What could it be?
caskiguy (07-28-2019)
#477
Not so light Minilites
Just spent three weeks vacationing in France. Back home now and saw your abondance of imagination. Impressive.
OK, so here are the British goods: Got the Minilites about three months after placing the order. 15x10 for the rear & 10x9 for the front, with the smallest backspace that they offer.
The following 3 users liked this post by RBrid:
RBrid (09-21-2019)
#480
Step 1: symetry is queen
(yes, not king - symétrie is feminine in French)
Time for an update folks. Here are the 9 steps I went through to set up the L88 headlight covers.
First, cut one edge of each aluminum bracket so that the 7 holes are centered. Could not live with an asymmetrical layout.
Here's a picture from years ago showing what triggered my OCD.
