74 alignment
Old Sep 28, 2013 | 10:18 AM
llabesab7's Avatar
llabesab7
Default 74 alignment
just bought a 74. It pulls to the right a little. Is alignment complicated and how much does it cost. My 1st Vette by the way.
Old Sep 28, 2013 | 11:17 AM
oledave60's Avatar
oledave60
It's not complicated if they have a modern machine. I just had my 75 done last week. They had a very fancy Hunter machine and I watched the computer screen to make sure it was in the spec I had brought with me. $49.95 for four wheel and it sure drives better.
Old Sep 28, 2013 | 12:27 PM
classicstingrays's Avatar
classicstingrays
Navigator
It's not complicated if they have a modern machine and a technician that is familiar with the process. You may want to bring in the spec sheet that you desire to have done. Most machines can print you a copy of the results. If you plan on getting the four wheel, bring extra shims for the trailing arms if the rear looks to be out very bad. $69.95 for four wheel on my 74.
Old Sep 28, 2013 | 12:40 PM
Mike Ward's Avatar
Mike Ward
It's all very easy and cheap IF:
  • they have the machine
  • they have the specs
  • they have the shims
  • they have a technician that knows his stuff
  • they don't find that the suspension is rusted to cr*p
  • they don't find other stuff that 'needs' changing
  • they charge a flat fee and not 'per hour'
otherwise, bend over and be ready to shed some tears. The chances that all seven conditions will be met is slim.
Old Sep 28, 2013 | 01:19 PM
Paul L's Avatar
Paul L
They will have the front shims but not the rear. Mike's #5 is important for the trailing arms (toe adjustment). Nothing may want to loosen.
Old Sep 28, 2013 | 07:49 PM
LS4 PILOT's Avatar
LS4 PILOT
My 74 was pulling just a little to the right too....about 2 months ago.
Rebuilt the rear suspension , bearings etc...new trailing arms , front bearings too. Stainless rear shims .
Costs depends on the lack of prior upkeep. And if you do it yourself.
Tracks , straight as an arrow handles sweet. Worth every penny to me.
Nothing but money and time ....all it takes
Old Sep 28, 2013 | 11:07 PM
llabesab7's Avatar
llabesab7
Thanks to everyone for the alignment help
To 74 alignment
