79 Random Wire
Old Oct 7, 2013 | 02:58 PM
bballboy06's Avatar
bballboy06
Default 79 Random Wire
Can anyone tell me there thoughts on where this wire should go?
it is hot then the ignition is turned on.
thanks
Old Oct 7, 2013 | 02:59 PM
bballboy06's Avatar
bballboy06
thanks
we are looking at the blue wire right on top...
Old Oct 7, 2013 | 03:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's not stock. Where does it go after snaking around the distributor?
Old Oct 7, 2013 | 03:33 PM
MelWff's Avatar
MelWff
Is there anything not working? Do you have an electric choke?
Old Oct 7, 2013 | 03:43 PM
bballboy06's Avatar
bballboy06
it goes into the wiring harness then through the firewall, i do believe it is stock
Old Oct 7, 2013 | 03:45 PM
bballboy06's Avatar
bballboy06
the only thing i can think of is that i have a GEN light on and also my headlights dont pop....i do not believe i have a electric choke.....car does not like to start at cold tho...
Old Oct 7, 2013 | 04:14 PM
Easy Mike's Avatar
Easy Mike
Headlights open and close by vacuum, not electric.
Old Oct 7, 2013 | 08:55 PM
speedreed8's Avatar
speedreed8
looks like the wiring for the electric aux. fan, looks like you have an L82 / w AC. those cars got the electric fan mounted in the shroud.....
Old Oct 7, 2013 | 09:16 PM
bballboy06's Avatar
bballboy06
that is correct it is an L-82, where does that connect?does it connect to another wire?
thanks
Old Oct 8, 2013 | 07:12 PM
bballboy06's Avatar
bballboy06
thanks
bump
Old Oct 8, 2013 | 09:25 PM
speedreed8's Avatar
speedreed8
the blue wire(+) went to an electric fan motor in the shroud, it plugged into the motor , then a black wire (-) came back through a temp. sensor in the cyl. head, then to frame ground. the sensor was set at about 235°.
Old Oct 9, 2013 | 08:50 AM
Street Rat's Avatar
Street Rat
Old Oct 9, 2013 | 11:02 AM
bballboy06's Avatar
bballboy06
can anyone take a picture of the temp sensor so i know what i am looking at?
thanks
To 79 Random Wire
