My 1973 Frame off Follow along the Restration
Old 06-18-2017, 11:19 AM
  #341
Tim 1973
Tim 1973's Avatar
Good afternoon all from Sunny California. I'm on a Vacation spending time with the Kids and Grand kids. I'll be back in Texas on Wednesday and back to working on the 73. I did some work last week that I will report on once back Home...
Old 06-21-2017, 11:40 PM
  #342
Tim 1973
Tim 1973's Avatar
Last week before I went to Calif, I worked on the gauges, got them all working...
Got off work early today and stooped by Tractor supply. Picked up all the mounting bolts I need to hook the body to the sub frame. Not going to use the new bolts with the new body cushions. I'm using the neoprene set that I'm not going to use. they will stay with rotisserie sub frame when I sell it.
I still need to make a front mount to attach to the Radiator mounting points... some 1 1/2" angle should work so I'll go pick up 10' tomorrow.
Old 06-22-2017, 10:44 PM
  #343
Tim 1973
Tim 1973's Avatar
Today I only had a little time to work plus the shop AC unit is not working and its to hot to spend too long in the shop. AC guy will be here tomorrow...
I pulled the Passenger side seat belt mount off.
old and new Seat Belt mount
Old 07-01-2017, 01:17 AM
  #344
Tim 1973
Tim 1973's Avatar
Tonight I decided to install the rear shafts safety loops. Its hot in the shop and did not turn the AC on so only spent 3 hours in the shop.
Old 07-01-2017, 07:59 AM
  #345
mysticpete
mysticpete's Avatar
Hey Tim, Pete here, what made you go from the LS1 to LS3?
Old 07-01-2017, 12:00 PM
  #346
Tim 1973
Tim 1973's Avatar
Hi Pete,
this project has made a few turns from the beginning, First I was going to stay with a Big block, I then seen some Restro mods and plan on doing some road trips with it so I decided a LS motor was the route I wanted to go. I was planing on going with the 454 LS but the cost was a bit much. I had a LS block I was using to mock up and get motor mount making sure it was all fitting correctly I also had a old 4l60E I picked up. One day they had a sale on the LS3 525HP version. The engine was complete and almost turn key and would not need to do any work on it and could put my energy to other I parts of the build. Once I got the Crate Motor I became sick that but me back over a year.
I'm now ok but my Job has me traveling a lot so I'm glad I went in that direction.
Tim
mysticpete (07-01-2017)
Old 07-10-2017, 09:40 PM
  #347
Tim 1973
Tim 1973's Avatar
I was able to get in the shop for a few hours today... Picked up the 2 1/2" x 2 1/2" 3/16 tube this morning to build the front connections
got all four mounts welded
Vette off the wheels and being held up by rotisserie
Tim
Old 07-15-2017, 05:34 PM
  #348
Tim 1973
Tim 1973's Avatar
Spent a few hours last night finishing up on the rot mounts. Its finally finished..
mysticpete (07-15-2017)
Old 07-15-2017, 06:19 PM
  #349
mysticpete
mysticpete's Avatar
Great work Tim, I need to re-read this post again!
Old 07-15-2017, 06:22 PM
  #350
Tim 1973
Tim 1973's Avatar
Pete
Old 07-15-2017, 06:30 PM
  #351
mysticpete
mysticpete's Avatar
OK Tim... First Q: You live in Texas and you installed seat warmers!!!!
  #352
Tim 1973
Tim 1973's Avatar
I'm headed to Colorado Springs tomorrow, Working at Cheyenne Mountain and Peterson AFB should be back in 2 weeks... I have ordered the paint.. The fun will begin soon. Cement guys will be pouring the slab for the extension for my shop 36' x 30 the week I return.
Old 07-15-2017, 06:33 PM
  #353
Tim 1973
Tim 1973's Avatar
Yes I did for my wife. In the colder time of the year my wife uses her's in her Camaro all the time.. Yea in Texas..
Old 08-21-2017, 03:36 PM
  #354
Tim 1973
Tim 1973's Avatar
Just wanted make a update. I have been doing a lot of work on the 73. Just not much to post.. I finished the power steering lines and filled up with fluid. Lots of fiberglass work under the Daytona front end to fit it all up to the front bumper lower valance air dam panel.
Facebook Post
The following 2 users liked this post by Tim 1973:
jr73 (08-21-2017), mysticpete (08-24-2017)
Old 08-21-2017, 08:53 PM
  #355
Jeff k
Jeff k's Avatar
Looking good Tim!
I'm trying to catch up, bit by bit......
Old 08-21-2017, 10:56 PM
  #356
Tim 1973
Tim 1973's Avatar
Jeff to you have a build thread? a few questions on your build. How are you going to deal with the heater lines? Also it appears your power steering pump pulley is very close to your a arm. It also looks like you have no shims in the arm for alignment. Once you get to that stage you might have issues.
Old 08-22-2017, 12:01 AM
  #357
caskiguy
Support Corvetteforum!
caskiguy's Avatar
Originally Posted by Jeff k
Looking good Tim!
To My 1973 Frame off Follow along the Restration
Old 08-22-2017, 06:28 AM
  #358
Jeff k
Jeff k's Avatar
Tim,
no build thread yet, maybe later? As far as the p/s pulley clearance,there is over 3/4" to the a arm bolt. I think the angle of the photo makes it look closer.
The a arms have a couple of shims installed right now, just as a guess. The a arms are Global West tubular and have additional caster built in so I'm just eyeballing it right now.
​​​​​​ keep up the good work, your car is looking great!
Jeff
Old 08-22-2017, 06:34 AM
  #359
Jeff k
Jeff k's Avatar
Probably going to weld in fittings on the water pump as you did, saw you had some leakage when hey were just tapped and threaded in. Confirmed my direction and plan.
Jeff
Old 08-22-2017, 07:32 PM
  #360
Tim 1973
Tim 1973's Avatar
Jeff
Yes I did had leakage before I went to weld on bung's I have had water in my rad for a few months with no leakage. The metal is very thin for sealing if taped. I used AN- fittings and presently have plugs at the end on the fittings. once I put the body back on the frame I will fit the black braided lines to the heater.
Quick Reply: My 1973 Frame off Follow along the Restration
