I need info re: 1981 power antenna bezel. Ordered gasket from Ecklers but cannot find a vendor for bezel or bezel/nut part(s) for 81 power antenna. Can non-power bezel be used? I do not need the chrome bottom ring, but the bezel holding the ring and gasket to the body. Thanks for any help.
Most major supporting vendors have what you need, if I think I know what you are talking about. The piece that you see when the antenna is retracted that is threaded on the inside? I recently purchased one myself for my '80 and assume they are the same.
