Relay Does What ?
Old Oct 26, 2013 | 12:46 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Default Relay Does What ?
My Tech manuals didn't arrive yet....need help!
"NEW-RESCUE" '68 convertible
327 engine A/T
No A/C
No power accessories
This relay (among many others) was disconnected under the console forward of the shifter assembly.....
What colore-coded wiring connector attaches to the 3 prongs?
What color-coded connector attaches to the separate 2-prongs?
RATTTTTTTS...fuzzy pics....
3-prong section is in triangular shape
2-prong section located 1/2" from 3-prong is in-line
Thanks in advance for bailing me out
Old Oct 26, 2013 | 01:59 PM
doorgunner's Avatar
doorgunner
I'm going back to the garage to sulk until I get some help
LOL!
Old Oct 26, 2013 | 03:12 PM
DZRick's Avatar
DZRick
That is the wiper relay.
I'll find Willcox's drawing for the connector/wire colors.
Old Oct 26, 2013 | 03:20 PM
DZRick's Avatar
DZRick
1st post of the last page has the diagram. If you find it hard to see where each wire lands, Ernie was kind enough to put colored dots right of the relay terminals.
http://forums.corvetteforum.com/c3-g...r-motor-7.html
Old Oct 26, 2013 | 09:02 PM
doorgunner's Avatar
doorgunner
Thanks DZR.....my new wiring harness was one color different than the hacked-up/spliced/w/telephone wire OEM harness....
which was more than enough to fry my wittle brain....
Black/Black-White/Green
Yellow/Blue
EDIT: Talk about timing...my wife just handed me a UPS box................with a wiper switch inside.....!
I can now assemble the console/wiring/duct-cables/etc. in the morning...it would have gotten done today.......
BUT.....there was a small snag-----since the interior components were disassembled by the previous owner, so I had no idea that the Hurst A/T shifter was 2" TOO TALL for the console to bolt in place properly.
Two hours later I had fabbed a shifter mounting plate that bolted 2" below the surface of the tunnel/mounted the shifter to it....the shifter and console fit fine now! When I drop the A/T transmission next week I'll fiberglass a box around the lowered mounting plate and add insulation to the tunnel area to avoid heat being drawn in under the console.
Old Oct 27, 2013 | 08:18 AM
Roco71's Avatar
Roco71
I believe that is the wiper relay.
Old Oct 27, 2013 | 11:24 PM
doorgunner's Avatar
doorgunner
I (re)connected it with the new harness.....the wipers are wipin' better than ever.
Old Oct 28, 2013 | 09:58 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'm glad you got them working.
To Relay Does What ?
