Hey all, I have a 1978 Corvette and I am trying to narrow down where the issue is with the headlight vacuum. I am hoping that if I describe how things are currently working, I can get some tips on what to specifically address. So if the car is running, in park and I pull the headlight ****, the driver side headlight goes up somewhat slow but the passenger side goes very up slow and only about half way. If driving, and I pull the headlight ****, the driver side opens extremely slow and the passenger side doesn't open at all. With the engine running and in park, if I pull the switch under the steering wheel, both headlights will go up (little slow). Any ideas or thoughts?
I have a similar issue, drive side pops up and the passenger side I have to lift up by hand. Mine is a 1973 and who knows what the previous owner did or didn't do if anything at all. I figure the best place to start was with replacing 40 year old Vacuum lines.
You can get the complete set of lines from Eckler's, color coded and with a diagram as well.
This rookie always repairs the least expensive part first:
Sounds like there's not enough vacuum being supplied to operate the system.....OR.....there's enough vacuum being supplied---but it's being lost somewhere in the system
Check vacuum line connections at components and at vacuum switches for looseness or cracked vacuum hose ends.
I would think that the vacuum check valve may be going bad (it keeps vacuum from leaking out of cannister)
TRY cutting the ends of the vac lines off(1/2 inch) to see if they are too loose, letting them suck air. If that doesn't work, go the Willcox web site, they have a site to help with this and most problems!
