Toque Converter bolt patterns
Old Oct 27, 2013 | 10:34 AM
Vette Rookie's Avatar
Vette Rookie
Default Toque Converter bolt patterns
Finally getting around to putting the motor together for my 73 rebuild. Can anyone give me a little information on which bolt pattern to look for in a flex plate? Basically is there a preference between the 10.75 and 11.5 inch torque converter bolt patterns. The motor is a 427 and trans will either be a TH400 or 700R4. Will this change anything?
Old Oct 27, 2013 | 05:20 PM
TimAT's Avatar
TimAT
You can get a flexplate that is "double drilled" meaning it will fit the 350/400 convertor bolt pattern or the metric 200/700R4. Other than that, the 427 is internally balanced, so the new flexplate will not have an additional weight on it and be neutral balanced.
Old Oct 27, 2013 | 09:34 PM
Vette Rookie
So the different sizes relate to the transmission size 350 or 400?
Old Oct 27, 2013 | 11:45 PM
TimAT's Avatar
TimAT
Sort of. Chevrolet used 2 different diameter 'wheels depending on application. 153 or 168 teeth. (counting the teeth on the flywheel/flexplate ring gear.
Read this- it may shed some more light for you. This was written thinking of the SBC, and you have a BB 427. Pretty much the same except for application.
http://www.speedwaymotors.com/small-...-flexplate.dlp
Old Oct 28, 2013 | 12:13 AM
Vette Rookie
Thanks, that did help, now all I have to do is decide which starter bolt pattern is better, and the diameter of the torque converter will be.
To Toque Converter bolt patterns
