383 Stroker Help
I need some expert advice regarding a 383 stroker I had put in a little over two years ago.
Here’s what I know about the engine: The engine has a forged crank, forged pistons, and 6 inch I beam rods. The heads are World Products S/R Torquer Heads (aluminum) assembled with 2.02 valves, 76cc chambers. It has hydraulic flat tappet cam and lifters 230@.050 109LSA .480 lift. The engine has a Holley 750 80508S double pumper carburetor, Edelbrock aluminum intake, and HEI ignition.
Since I had the engine put in, it’s been running but I have a noticeable misfire. Specifically when I go full open throttle, it sounds like I’m running on 6 cylinders. I’ve tried several things to eliminate the issue including replacing the plugs (went to a hotter plug), plug wires, dist cap, rotor, and even the distributor (going to a HEI system) -- still no joy. Yesterday, I decided to do a compression test and here’s what I found:
8 – 180; 7 – 180
6 – 180; 5 – 175
4 – 172; 3 – 160
2 – 135; 1 – 155
I noticed that the sparkplugs in cylinders 4, 6, and 8 (Pictured) were heavy in oil and actually, the electrode was half black (oil I presume) and the other have was clean. Cylinders 1-3-5-7 looked like new plugs so I didn't include the pics but can if that would help. I will tell you this car is rarely driven; meaning it’s a weekend/sunny day driver only. With that in mind, I’m thinking the oil might be a result of the rings not seating yet.
In the interest of full disclosure, it did run hot on me one time last summer; didn’t realize it until it was the temp was 250 – once I noticed, I immediately shut her down. Turned out to be low coolant (but didn’t see any puddles in the garage).
The compression really has me baffled though; any divine guidance?
-Al
