I pulled my Quad and replaced it a "Lars" rebuilt and tuned Holley 4175. Very happy with it, no lag off idle and better gas mileage. I also changed my intake and went with the Edelbrock performer.
I believe what people are suggesting is that it may not be a carburetor issue. Personally, I feel that GM has engineered each carburetor to best match your (stock) engine.
Others prefer a Holley spreadbore, such as the 4165 or 4175. There may be fitment issues. The 6210-3 did not fit on my '69 L46 stock set-up - Bubba made some interesting modifications to make it fit. I replaced it with the correct quadrajet tuned by Lars.
I recently had my stock carburetor rebuilt, 3 times actually. The shop came highly recommended but I've had nothing but problems. Each time they rebuild and/or adjust the carburetor, the car runs fine for a day or so and then the starting problems return. Oftentimes, the car starts fine when cold but once I turn it off, it becomes increasingly difficult to restart it. I'm fed up with all these problems and have decided to replace the carburetor. Can anyone recommend a proper direct fit replacement? I live in California, so it should be 50 state legal and, being a C3, I don't have much hood clearance to accommodate a thick adapter plate. Any assistance will be greatly appreciated. Thanks.
Straight up answer here 79Shark, since CA is such a stickler on emissions, I would go with a CARB legal Holley Spread Bore if there is such a thing. If a Q-jet can pass the breath test, I don't see why a Holley wouldn't, and the Holley can actually work 2 days in a row!!
... Others prefer a Holley spreadbore, such as the 4165 or 4175. There may be fitment issues. The 6210-3 did not fit on my '69 L46 stock set-up...
Thanks, this is what I've come across so far. The specs on the carbs that I've looked at (Holley & Edelbrock) don't say if they are a direct fit (without adapters) and I'm concerned that adapters will cause clearance issues. I don't want to invest that much money on something that will require creative modifications.
I called J&D Corvette today, they haven't been able to look at the car yet, so the problems remain a mystery. I'm hoping to hear back from them by Friday. I'll post the results, whatever they may be. Again, thank you all for your input and suggestions. I find them very helpful.
76Vett, did you replace the intake because you wanted to or to better accommodate the Holley 4175?
... I was told the other day that all roads lead to Costa Mesa . . .
Steve, I was following the yellow brick road to Costa Mesa when fate intervened. With the engine temp at 260 I had no choice but to detour to Bellflower and keep my fingers crossed for now.
Steve, I was following the yellow brick road to Costa Mesa when fate intervened. With the engine temp at 260, I had no choice but to detour to Bellflower and keep my fingers crossed for now.
Hi again 79Shark. I see you've gotten a lot of confusing and conflicting info and opinions, so what the hell, I might as well cloud things up a little more. There are basically 2 carb mounting flanges: square bore and spread bore or Quadrajet style. Now the square bore comes in 2 sizes: Holley, and Carter AFB style. Although the Edelbrock carbs outwardly look like Carters, they're NOT compatible with stock AFB manifolds. They have Holley-size bases and air horns. The Holley spread bore was designed as a direct replacement for the Q-jet without the use of an adapter plate. The only confusion remaining with the spread bore is compatibility of chokes, vacuum ports and throttle/kickdown linkages. I'm a Holley guy myself and would have one on my PC but for the fact of trying to keep it all original. If I had a base Vette, it would have a Holley on it, or an Edelbrock EFI system for total worry-free driving. Clear as mud now, RIGHT?
I would be interested in knowing recommended replacements too. no excuses as to why. I just want to know.
The OP needs to have his original Qjet rebuilt PROPERLY if indeed the issue is the carb.
Any other type or brand of carb is probably going to present installation or compatibility issues, gain NOTHING in performance or economy and if it's of the same poor condition as the existing carb, be back at square one.
Q junk is garbage. Best left to the dog pile of time.
Holley is the only way to go for dependability, ease of tuning, ease of getting parts and any piece of mind.
I remember hearing that for the first time back in the early '70s coming from a new hire in the garage. The boss looked at him and said if you're not fit to keep a qjet running, you're not fit to change oil or pump up tires either. See ya.
He was right.
To the tune of the Kingston Trio.....
"Where have all the q jets gone? Long time passing
Where have all the q jets gone? Long time ago
Gone to graveyards every one
When will they ever learn, when will they ever learn?"
Have you been having to add coolant during the hard start problems?
I have seen cars that have had head gaskets leaking causing extended cranking time.
This usually happens when the car sits for a few hours and lets some water seep into the cylinders.
