75 Differential Inspection?
Old Oct 27, 2013 | 04:55 PM
bwinterstine's Avatar
bwinterstine
Default 75 Differential Inspection?
I'm documenting the rebuild of my 75 in a separate thread (Small Garage Restoration) but I wanted to ask a question outside of that thread. I'll update it with the results.
Background: My car is a L48 w/ 98K, automatic. I do not know the history of the car and have never driven it. It was a wreck when I bought it. I'm doing a frame off restoration. After the car is done, I intend to use the car as a weekend/show driver but it will not be raced or abused.
The differential is out of the car and drained. I don't feel any slop and I don't hear any strange noise when I turn the input shaft. I checked the left and right end play and they are 0.056 and 0.042.
I'm not a fan of fixing something that "ain't broke" so here's my question: Should I open it up and inspect it? If I do, what am I looking for?
Old Oct 28, 2013 | 11:49 AM
MelWff's Avatar
MelWff
I would open it up and check for any loose ring gear bolts, they cost me my original differential.
Old Oct 28, 2013 | 11:57 AM
Mike Ward's Avatar
Mike Ward
Spending a lot of money due to 'project creep'.
Old Oct 28, 2013 | 01:29 PM
bwinterstine
Trying to avoid the creep but we know how that goes.
So far, one vote to open it up and check the ring gear bolts...any other suggestions?
Old Oct 28, 2013 | 03:08 PM
Roco71's Avatar
Roco71
I would consider replacing the seals if nothing else while it was out.
Old Oct 28, 2013 | 08:36 PM
bwinterstine
Seals are probably a good idea ... I'll be opening up the rear this weekend. I have to see if I have a pair of 90 degree snap ring pliers ... not something I use often.
We all know what's going to happen once I open up the rear ... PROJECT CREEP.
Old Oct 28, 2013 | 09:11 PM
Roco71's Avatar
Roco71
Its just one of those things that if something goes wrong later you will wish you had done it because its a real pain to get to once its back together. So where do you draw the line? Down side is that it takes a few specialty tools to rebuild that most of us do not have in the tool box.
Old Oct 28, 2013 | 09:30 PM
lvmyvt76's Avatar
lvmyvt76
when I had mine out, I took it to a speed shop that does corvette rear ends, had them open it up, replaced all bearings, clutch pack, both shafts, and look at the play on the ring & pinion gears, also all seals. Put new fluid and additive from GM back in. Now no worries until after I am gone! ( around $550.00 back then)
Old Oct 29, 2013 | 08:27 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I agree. It is one of those things that you ought to go ahead and do now instead of after getting everything back together and finding a drip later. Plus it is one of the less enjoyable tasks in rebuilding a Corvette. Bite the bullet and fix it right while you have the opportunity.
Old Oct 30, 2013 | 01:58 PM
bwinterstine
I ordered new seals from Bair and they'll be here on Saturday. I've already removed the front/pinion yoke and both side stub axels. Everything appears to be in decent shape and the ring gear bolts are all tight.
I've got some wear on the stub axels, about 0.025 worn and they measure 0.162 (left) and 0.160 (right). Everything is marked to put it back as it was originally installed, especially the pinion nut. By the way, my electric harbor freight impact wrench made easy work of getting this nut off ... I was concerned that it would be tough.
One set of instructions stated that I had to remove the large pin in the carrier before I could take off the c-clips on the axel stubs. Not the case. Both sides came out easily with the pin installed but it would have been tough without 90 degree snap ring pliers.
Old Oct 31, 2013 | 10:02 AM
71scgc's Avatar
71scgc
Get a heavy duty diff cover. Muskegeon Brake.
Carter
Old Oct 31, 2013 | 04:16 PM
bwinterstine
Carter
Why do I need this? I don't see anything wrong with the stock cover.
To 75 Differential Inspection?
