I have a lightweight aluminum jack- short base that I can pick up and set on the ramps of the Kwik Lift. Jack the car, short jackstand under the frame and set the car on the stand. I rebuilt both front and rear suspension with the car setting on jackstands on the lift. The bridge is handy for a bottle jack if I need to jack the engine or trans a little bit. Mostly the bridge seem to be in the way. And I have 2 of them thinking that I'd need them to lift the car. Silly me.
TimAT , where did you purchase your jack stands and bottle jack?
I do have one center bridge but where the bridge sits there are no jack points? I envisioned using a 3" x 3" square metal bar with bottle jacks lifting from the center bridge ( as described in an earlier response) but that implies I need to purchase another center lift bridge to lift the back?
