79 L-82 Engine rebuild
Old Nov 1, 2013 | 02:48 PM
bballboy06's Avatar
bballboy06
Default 79 L-82 Engine rebuild
What should an engine rebuild cost?
is it more cost effective to drop in a crate engine?
thanks
Old Nov 1, 2013 | 02:53 PM
Revi's Avatar
Revi
Well it all depends on what you want to do and what your end goal is. Do you want a 300hp engine or a 1000hp engine?
The L-82 is a decent engine with most of the good parts. It's basically a 1970 L-46 with less compression. If you get the heads ported, upgrade the intake manifold and up the compression to 10.0-10.5:1 you'll have a 350-375hp (gross) engine.
Old Nov 1, 2013 | 03:21 PM
LS4 PILOT's Avatar
LS4 PILOT
Compression was the Killer of ALL cars after 1970. Chevrolets engines went LIMP with no compression .... Bring the COmpression back up to near 11:1 and it will run . The old 350 /350 was a sweet engine. Add a TRUE dual exhaust , NO SMOG or CATALYTIC converter , 3:70 gears and 4 or 5 speed it will still do decent.
Compression is one of the main ingredients . New cars have all the electronic computers to allow compression increases and still run on regular fuels .
Find a set of OLD 350HP 2:02 heads like from 68 -70
Or just call the junk yards like everybody does now days and get an engine out of dead GM VAN or GTO , Votecs and LS2 , and all that stuff.
Old Nov 1, 2013 | 03:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bballboy06
...What should an engine rebuild cost?...
Less than it does.
...is it more cost effective to drop in a crate engine?...
That depends. Do you have the skills and can you do the work rebuilding your L-82?
Old Nov 1, 2013 | 03:29 PM
dochorsepower's Avatar
dochorsepower
The basic L-82 was a tough motor. Why do you think you need a rebuild? Modern fast burn heads and a good cam will really wake up an L-82.
Old Nov 1, 2013 | 08:41 PM
Tooonz's Avatar
Tooonz
I'm in the process of taking my engine out, thought about a crate engine, can get different hp for cheap money. If it wasn't for the help of an old friend, I'd be putting in a crate engine. Of course I didn't have the original block. My plan is do what was just mentioned, got new heads and putting in anew cam. But I'm at the mercy of my buddy's ability to rebuild.
Old Nov 1, 2013 | 09:28 PM
bballboy06's Avatar
bballboy06
What heads would you reccomend? and what cam?
engine runs, just feels sluggish...
thanks
To 79 L-82 Engine rebuild
