How important is....
Old Nov 9, 2013 | 08:35 PM
Cavu2u's Avatar
Cavu2u
Default How important is....
#62, described as Splash Shield Gasket, on my '73?
Thanks.
Old Nov 9, 2013 | 09:07 PM
SIXFOOTER's Avatar
SIXFOOTER
you can use a little silicone or urethane in place of the gasket
Old Nov 10, 2013 | 12:17 AM
birdsmith's Avatar
birdsmith
I think the OE part was just oiled paper...you can make one easily enough. You just need to have some kind of rust barrier between the two parts like Sixfooter mentioned.
Old Nov 10, 2013 | 04:38 AM
Cavu2u's Avatar
Cavu2u
Thanks again for the response. I wasn't sure if it was a clearence required for something, or squeak prevention, or whatever. The left side knuckle I took off on this rebuild had caked-on gunk in this area. Apparently the bearing seal was leaking through the years. Will scrape it off with a putty knife and then clean up with solvent to see what I have. I'll make something out of paper gasket material for a replacement.
To How important is....
