Please help me ID this engine. ...
Old Nov 10, 2013 | 08:16 AM
Land Shark's Avatar
Land Shark
Default Please help me ID this engine. ...
The back of the block is 14010207, this I can find, but I can't find anything on the deck stamp:
CAZ106892
These numbers were also on deck plate:
1004TDR or 10041DR
Old Nov 10, 2013 | 09:11 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
80-85 Chevy truck...going by the block casting number alone, likely used for other applications
Old Nov 10, 2013 | 10:29 AM
Land Shark's Avatar
Land Shark
Did you find that off of casting number? I found that this block was also used in 80-85 vette's
What I can't find is info on the deck plate numbers.
Old Nov 10, 2013 | 10:31 AM
Land Shark's Avatar
Land Shark
What would be the value of a 71 in good condition but not numbers matching?
Old Nov 10, 2013 | 10:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Land Shark
...Did you find that off of casting number?...
No. http://www.clubhotrod.com/chevy-smal...4010207-a.html
The TDR suffix identifies the specific configuration.
Old Nov 10, 2013 | 11:14 AM
Land Shark's Avatar
Land Shark
Thanks, so much for this being an LT1!!!
Old Nov 10, 2013 | 11:33 AM
Land Shark's Avatar
Land Shark
Cyclinder heades seem to match LT1
3973487X
But I assume this doesn't make it numbers matching or period correct?
Old Nov 10, 2013 | 11:51 AM
Land Shark's Avatar
Land Shark
Do you have any idea what the CAZ suffix is for?
Old Nov 10, 2013 | 01:00 PM
David Mc's Avatar
David Mc
Wouldn't that be the prefix? When I lookup TDR I come up with Truck 350 1972 or 1980.
CAZ ,I think, is part of the VIN sequence. Trucks did not have their VIN's on the pad in '72 and were 010 blocks (350).
Old Nov 10, 2013 | 01:04 PM
Land Shark's Avatar
Land Shark
That's why I come here, for good info!
Old Nov 10, 2013 | 01:27 PM
71 Green 454's Avatar
71 Green 454
Check this site:
http://www.nastyz28.com/chevy-engine...ngs.php#suffix
It's correct for my '71 LS5 with a CPH suffix.
Also, casting # 14010207 listed here:
http://outintheshop.com/faq/casting/castings2.html
14010207= 1980-1985, 350, car & Truck 2 & 4-Bolt Passenger stick
Old Nov 10, 2013 | 01:32 PM
Mike Ward's Avatar
Mike Ward
Pretty sure they did have VINs on the pads at least on light trucks that used the 0010 blocks.
The OP has a 14010207 casting number that didn't exist till 1980.
3973487X heads were used on all sorts of cars and trucks, not just LT1.
Old Nov 10, 2013 | 04:13 PM
David Mc's Avatar
David Mc
I still own a '72 K20 Suburban but it has a Corvette engine (really a L82).
I'm a member on the forum too and the experts over there say no VIN's on the truck blocks.
It's a question that gets ask regularly.
Old Nov 10, 2013 | 04:35 PM
Land Shark's Avatar
Land Shark
I know, I've been reading so many different articles and some say truck, some say it was only made 80-85 and some say 2 or 4 bolt. The only thing I know for sure is that it is not an LT1:-(
Old Nov 10, 2013 | 05:39 PM
Mike Ward's Avatar
Mike Ward
NO, ALL the posts say 1980 truck.
If you want precise info:
1980 TDR: a/t, California, C-10 & 15 trucks, VIN starts with L, RPO LS9 155HP, 4 barrel
Old Nov 10, 2013 | 06:04 PM
Land Shark's Avatar
Land Shark
Do you know where I can find numbers on frame and rear end to tell if it was LT1
Old Nov 11, 2013 | 08:17 AM
Revi's Avatar
Revi
There is nothing on the frame or rearend to identify an LT-1.
What is redline on the tach? If it is 6500rpm it could be an LT-1 or it could have a replacement tach installed.
If it has a tach with a lesser redline (5200, 5600) it most likely isn't an LT-1.
To Please help me ID this engine. ...
Old Nov 11, 2013 | 09:05 AM
MidShark's Avatar
MidShark
On your other thread you say the car is an automatic. While not completely out of the realm of possibility, I find it highly unlikely that someone converted the 4-speed to an automatic (NO LT-1s came with an auto, despite what the seller told you). You can check the tach as recommended, the car would have a single fuel line (no return line), it would have the heavy duty half-shalfs with caps and bolts (not u-bolts), and there should still be a transistorized ignition amplifier hidden on the headight side of the driver's front inner fender, along with the wiring for the amp running along the harness on the driver's side. I wouldn't hold my breath on finding any of those things.
It's already been established that your engine is an early '80s 350 (didn't the seller tell you it was matching numbers?) and I would have to say it's most likely that it was a base motor auto from the factory. Just enjoy it for what it is, unless you want to go back on the seller.
Old Nov 11, 2013 | 11:13 AM
Land Shark's Avatar
Land Shark
[QUOTE=MidShark;1585400347]On your other thread you say the car is an automatic. While not completely out of the realm of possibility, I find it highly unlikely that someone converted the 4-speed to an automatic (NO LT-1s came with an auto, despite what the seller told you). You can check the tach as recommended, the car would have a single fuel line (no return line), it would have the heavy duty half-shalfs with caps and bolts (not u-bolts), and there should still be a transistorized ignition amplifier hidden on the headight side of the driver's front inner fender, along with the wiring for the amp running along the harness on the driver's side. I wouldn't hold my breath on finding any of those things.
It's already been established that your engine is an early '80s 350 (didn't the seller tell you it was matching numbers?) and I would have to say it's most likely that it was a base motor auto from the factory. Just enjoy it for what it is, unless you want to go back on the seller.[/
I do believe after looking for all the signs of an LT1, that you are right, base model automatic:-(
Now its a question of value? Is 12k fair or to much??
Old Nov 11, 2013 | 11:54 AM
joewill's Avatar
joewill
people have paid more for a less condition car.. and they have paid less for a better condition car.. if I was looking, I would probably pay 12K for a decent condition 71. you are in the ballpark...still depends on the condition of the car since its originality has been determined. Since it is NOM, then most of the originality premium is thrown out the window. the price basis is more properly determined by its condition.
