Shock mount pita
Old Nov 10, 2013 | 04:39 PM
7tSixStingray's Avatar
7tSixStingray
Default Shock mount pita
Drivers side shock mount will not budge. The only heat I have is a propane torch for plumbing. Any suggestions? What is my plan B if it never comes out? Got a brand new in the box Milwaukee sawzall with a 9" diamond diablo blade I was saving for the trailing arm bolts.
Old Nov 10, 2013 | 05:59 PM
MidShark's Avatar
MidShark
I had the same problem on my '75 last winter. The passenger side came out easily, but the driver's side was rusted/frozen from the mouse pee dripping on it from the mouse who lived in the trailing arm. I actually bent the end of the shock mount from all the hammering. I ended up cutting through the shock mount on both sides of the strut arm and buying a new LH shock mount for $40. I would recommend getting more sawzall blades.
Did you soak it good with penatrating oil for a couple of days?
Old Nov 10, 2013 | 06:09 PM
TimAT's Avatar
TimAT
Soak it with ATF/acetone, mouse milk, or Hoppe's #9 gun solvent. If you can, immerse the whole think in a coffee can full of one of those and let it soak for a day or two. Put a big C clamp on the strut arms just above the shock mount for support. I used a nut, turned around backward so the castellation was toward the shock on flush with the end of the mount and hit that. I've heard, no personal experience, that a 3/4 iron pipe cap will work too.
Old Nov 10, 2013 | 06:44 PM
Roco71's Avatar
Roco71
I cut my strut rod with cut off wheel.
http://forums.corvetteforum.com/c3-t...ock-mount.html
Old Nov 10, 2013 | 06:58 PM
prlwng's Avatar
prlwng
Read of late useing candle wax to loosen rusted nuts.
Maybe a search could find it.
Old Nov 10, 2013 | 07:11 PM
7tSixStingray
Midshark; soaked with PB for a week, passenger side fell out, driver side stopped all production! Convincing myself to cut it, but worried about alignment issues after replacing the strut rod. I don't know much about that stuff and need to learn the impact of my actions prior to chopping.
Old Nov 10, 2013 | 07:13 PM
7tSixStingray
TimAT; going to soak the mount in a zip lock of brake fluid and hope for the best. Tried to buy a pipe cap but the local ace hardware said that plumbing threads were different (than the castle nut I handed to them) and sent me home with nothing?! I ended up threading on a normal nut and smacked it with a sledge 40 or 50 times. One out, one stuck!
Old Nov 10, 2013 | 07:15 PM
7tSixStingray
Roco71; I'm nearing the cutting option. Thanks for the link, my initial search lead me to that thread, but I recall reading that resurrecting old threads is frowned upon so I started this one. I got the zip lock/brake fluid idea from that one.
7tSixStingray
prlwng; I read that recently too. Nearing the point of trying anything!!!!
Old Nov 10, 2013 | 07:39 PM
TimAT's Avatar
TimAT
Not to rain on the parade, but I don't think brake fluid will have the rust penetrating quality you need.
The problem is the sleeve inside the rubber on the lower end of the shock is rusted to the shock mount. The brake fluid will kill the rubber, but I don't think it'll do much on the rust.
Old Nov 10, 2013 | 07:43 PM
7tSixStingray
TimAT; you're saying use the c clamp to stabilize the arm prior to smacking the shock mount with a sledge, right? Just want to make sure that I am understanding correctly. Thanks-
Old Nov 10, 2013 | 07:53 PM
TimAT's Avatar
TimAT
Correct- put a c clamp just above the shock mount so it is solid when you strike it. If you have help, have the helper put a big hammer on the clamp to back it up. It's possible that with no support, you can break the bearing housing if the rear breaks free and the front does not.
The clamp makes the whole thing more solid- the bearing housing is cast, but it still will bounce a little when you hit it.
Old Nov 10, 2013 | 08:15 PM
DonnieP73's Avatar
DonnieP73
Soaked mine in BP Blaster then used tie-rod (not ball joint) pickle fork.
You can borrow tool from Auto Zone free.
Donnie
Old Nov 10, 2013 | 08:43 PM
billcarson's Avatar
billcarson
use a small 2 arm wheel puller and tap in halved lock washers in between the strut rod end supports and the strut rod end.this will help deliver maximum force to the shock support.i have avoided much collateral damage by doing things this way.i do not use a bfh for anything nor a pickelfork for that matter.a c3 guy from the past suggested molding hd foil wrap around the assembly and soaking it with pb blaster for a few days.the foil kept the blaster where it could do most good. good luck.
Old Nov 11, 2013 | 08:24 PM
72LS1Vette's Avatar
72LS1Vette
The Ace guy was wrong, but from what I've read the pipe cap probably won't help anyway. I had a frozen strut mount, and the inner sleeve of the strut rod bushing had rustwelded itself to the shock mount. I was trading in my trailing arms for a rebuilt set so I sawed off the strut rod and let VanSteel worry about getting the mount off.
I've heard that Lennox blades are great for sawing through grade 8 bolts so if you can get the sawsall in there you can probably saw the bolt off.
Rick B.
To Shock mount pita
