When we aquired our car, it did not have A/C in it anymore, the condenser is there, but the hoses had been cut and no a/c compressor or brackets.
In a search for some parts, I found a guy who had an A/C cpmressor out of an '81 with all the hoses, he says it spins freely. My question is how do I know if the unit will be good until I hook it up? Is all you need to do is see if it spins freely?
I dont think spinning freely is a good criteria for judging condition. If the seals are shot it would still spin freely. Better off buying a rebuilt unit that you know can be returned if there are any issues.
I.M.H.O. Trying to fix a '79 A/C system with '81 parts is a waste of time and money. When I got my '79 I tried to have it tested and charged with R-134a. It worked for almost a month before the compressor blew. I got a Sanden compressor with the correct mounting brackets, accumulator, and hoses from Vintage Air as a kit for around $500.00. It's worked perfectly and blows very cold. I was able to install it myself, then had it charged at a shop.
Used A/C compressors are only good to use as a core-
I'd never put one on my car as-is.
Unless it was immediately sealed when it was removed from the donor car (provided it even worked then?), you have NO idea what kind of crap and corruption are inside. Not worth contaminating the rest of your system over.
Another point to ponder- The condenser is aluminum- the moisture in the air and the Freon (R-12), and the oil don't get along very well when the system is open. The aluminum tubes start to corrode on the inside. Pinhole leaks are possible.
Man this isn't sounding better. We'll he has a good radiator support that I'll be picking up anyway. I'll go back to focusing on the engine and compartment . I've got plenty of work to do with that. I was just hoping to get a break
T...I'm not even sure what is supposed to be there for parts. All I have is the condenser and some cut hoses...
Order the assembly instruction manual (AIM). It shows everything which is supposed to be there, shows how the parts install, and lists the original GM part numbers for everything.
You're working with one hand tied behind your back if you do not have the AIM.
