1976 gas tank
Old Nov 15, 2013 | 10:25 AM
7tSixStingray's Avatar
7tSixStingray
Default 1976 gas tank
Can anyone confirm for me whether or not the procedure to remove a 76 gas tank is the same as it would be for an earlier c3? I've found threads that detail removing a 74 or 69 gas tank and assumed that the same steps would apply to my 76. I figured I might as well grab the build sheet and replace the rubber hoses while the rear suspention is out. Thanks in advance for the help.
Old Nov 15, 2013 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
All the tanks installed essentially the same way. Some model years have a protective cover over the tank. Do you have the 76 AIM? If you have the cover, the AIM will show it.
