1968 Corvette Bumper Brace
Old Nov 19, 2013 | 10:40 AM
Duffeball's Avatar
Duffeball
Default 1968 Corvette Bumper Brace
I just want to confirm what I think I might know. I'm working on getting my bumper in shape before I let a paint guy paint my car. I acquired a bumper brace that is bolted to the frame off ebay. the seller listed it as a 1968 bumper brace.
When i went to bolt it to my frame, the bolt holes didn't line up with the holes on the frame. The holes on the frame seem to be more widely spaced.
Did I fall victim to the dreaded 69 part that doesn't fit a 68? What would you recommend? should I drill out the slots to accommodate the later year bumper brace? Or should I start the hunt for an original.
Old Nov 19, 2013 | 11:22 AM
MelWff's Avatar
MelWff
I guess that depends on what you intend to do with the car. If this is a driver it wont make any difference.
Old Nov 20, 2013 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Horse collar? If memory serves, one size fits all 68-72.
Old Nov 20, 2013 | 07:34 PM
loup68's Avatar
loup68
Army
Duffeball, Do you mean the large center brace, or the outer "dog leg" braces? On a 68, the front frame "ears" have a bracket on each side that are 68 specific, due to the hole spacing on the frame ears. On a 69-72, I think, the brackets are the same. The outer bumper "dog leg" braces bolt to this. Also the front cross member, that holds the radiator support, bolts to the bottom of this bracket. Hope this helps. Lou.
Old Nov 20, 2013 | 08:15 PM
JimE's Avatar
JimE
The outer front bumper braces for 68 are different than 69, different part numbers.
Old Nov 21, 2013 | 08:59 AM
Duffeball's Avatar
Duffeball
It will be a driven car. I am referring to the outer most " dog leg" brace that goes through the fender skirt out to the corner of the fender. so the ends of those are even different from 68 to 69?
anyone have a spare laying around they'd like to trade for a 69? ha. I'll have to start scouring.
Old Nov 21, 2013 | 11:25 PM
azza2u's Avatar
azza2u
From what I've come across the angle on the 68 bumper support bracket may also be slightly different to that on 69+ (not to mention the early 68 bumper itself is different to 69+)
Azza
Old Nov 22, 2013 | 08:25 PM
loup68's Avatar
loup68
Army
68 And 69 front, outer bumper braces should be the same. The 70 to 72 braces have a different angle to them. I do not know about different part numbers on a 68 and a 69. By the way, my company made those braces but I did not start working there in maintenance until September of 1974. If the original 68 and 69 braces are different, I wish someone would post pictures of them. We made many "service part" braces. One for 68,69 and the quite different 70-72. Lou.
To 1968 Corvette Bumper Brace
