pop up light problem, 1978 c3
Old Nov 27, 2013 | 09:30 AM
wagggawoo's Avatar
wagggawoo
Cruising
Default pop up light problem, 1978 c3
my left light would take awhile to pop up. I sprayed everything with WD 40 and it works great. I was also told you could take one of the springs off or replace the rubber grommet inside the can. I was told it was easy to do. Just thought I'd pass the info along
Zoot
Old Nov 27, 2013 | 11:23 AM
MelWff's Avatar
MelWff
If the underlying problem is a vacuum leak removing a spring doesnt resolve the real problem. Download this document and fix the real problem.
http://willcoxcorvette.com/instructi...ted_080509.pdf
