69 body mount 3
Old Nov 29, 2013 | 05:46 PM
SB64's Avatar
SB64
Default 69 body mount 3
So In my quest to remove the body from the frame I thought let me take the cover off and check the #3 mount. Pulled up my seat on wheels reach in with a 5/8 socket, that did not fit 11/16 no, 9/16no what the h-ll so I got my light looked inside and some of the head on the bolt rusted away. Dremel with a 90 bend attachment and a metal cutting blade did the trick for know . Fun Fun Fun. I am a patient man and I can see that this will be a challenge. Ill get some pics.
Old Nov 30, 2013 | 11:50 AM
TWINRAY's Avatar
TWINRAY
It should have taken a "regular" socket size (not metric) unless it was messed with before.
Old Nov 30, 2013 | 11:56 AM
SB64's Avatar
SB64
I agree, I think somebody tried to remove th bolt ,rounded it off then the rust got to it and bam no socket fits. Will be looking at the other side today.
Old Dec 1, 2013 | 03:00 PM
TWINRAY's Avatar
TWINRAY
I sprayed mine with PB blaster for at least a week before I tried to remove them - one thing you don't want to do is spin the cages
Old Dec 1, 2013 | 08:16 PM
SB64's Avatar
SB64
Default body off
I was able to unbolt mounts 1 & 2 mount 3&4 were dremilized, onto the passenger side. Also removed ground wires while I was near mount 1. Trying to be ready for lift off in a couple of days.
Old Dec 1, 2013 | 09:12 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
That's sad to hear. Hopefully you will be able to get the threads out from the caged nut. Do you have the ability to weld a nut on top of the old bolt once the body is off?
Old Dec 2, 2013 | 08:09 PM
SB64's Avatar
SB64
I thought once the body was off I would weld a bolt and soak and heat to get remainder of bolt out.
To 69 body mount 3
