Side mirror repair
Old Dec 5, 2013 | 01:23 PM
Vettereturned's Avatar
Vettereturned
Default Side mirror repair
So based upon what I've learned on this great forum I tried repairing my loose side view mirror. As learned I soaked the mirror in gas overnight. I tried to pry the mirror out (mistake) as I put a tiny chip on the glass. Here's my tip - I used my 'speed pass' for toll roads. I used the suction cups on the speed pass to pull the mirror off. The ball socket on mine was screwed down against a nylon washer that had split thus loosing all tension. I replaced the washer with a 'better' (quality I hope) nylon washer and re RTV'd the mirror. Hopefully the suction cup tip will help others if they try the repair.
Old Dec 5, 2013 | 01:30 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Good tip. Mine fell right out after soaking overnight.
Old Dec 5, 2013 | 01:38 PM
Vettereturned
Yeah I wasn't so lucky. I even used Ethanol Free 90 Octane gas! lol
Old Feb 24, 2014 | 02:24 PM
Vettereturned
WTH!! That was short lived. A few weeks back I was blowing my own horn on fixing my side view mirror. Well - it failed again and is loose, moving around at 70MPH. (My head hurts from move around with it looking for cars!) When I'd repaired it I'd RTV the mirror in so good that I'm not even attempting to remove it again so I've ordered a new mirror piece. My question for anyone is as follows; is there anything other than a nylon washer to hold the required tension against the ball socket? I suspect I had over tightened the bar and it caused the washer to split out again. I'm trying to think of better way. All suggestions are and will be appreciated.
FYI - the replacement mirror glass was $19.99 with shipping, so I figured Id try it again before I just order a completely new mirror assembly.
I'm currently thinking if I add multiple thinner nylon washers it may not be as susceptible to split out as one thick washer. Any Engineers out there to comment / suggest ?
Old Feb 25, 2014 | 11:52 AM
Doug Kraft's Avatar
Doug Kraft
Not sure but I read somewhere that a small metal washer was used instead.
Old Feb 25, 2014 | 01:20 PM
Vettereturned
Thanks Doug, it's worth a try; maybe brass.
To Side mirror repair
