Distributor Installation
*Edit* - My new wires are 8mm.
We, the majority, certainly went way past " TIMING 101"...but education was surely needed on this subject evidently...and now for all future timing headshakers....timing will be so much easier thanks to our posts from us...the retards of the Corvette world, except for the closed minds who will never learn.
I had a hunch that, as far as operating capability, #1 could be any tower. This replacement distributor ain't stock, so no external coil or points with this one. But the tach cable does require the body to be positioned one way for join-up, so that part of my question was answered before the thread started.
Mike; Thank you for the photo. Can't beat visuals for explanations to dunces like me.
Let's close this thread,
, unless more laughs are in order.
The wiring is simple. Switched 12V to the distributor.
On my 49 Chevy fleetline with a hot 283 with a HEI dist, the wire marked tach goes to an electric tach....and the other BAT wire terminal( probably the red one) comes straight off the starter switch from the switched power side ( not the full time power side).
On my 68, one wire hooked to the coil I think it is, is a resistor wire, it is a light tan color and the wire coming from the starter will not be needed by the new HEI dist in my opinion.
Just for your info, I am thinking about going back to a old dist on my 49, in fact, I ordered an old one off of EBay yesterday,I cannot get a good mech advance out of the two HEI's I have as they are a emissions part...they have very strong springs and even using weak springs...does not seem to help....I can only get about 30 degrees out of my HEI....my 283 needs much more as quick winding as it is...
I know my 68 without HEI is one quick fast car and it revs quickly...but it was balanced way back when local Nascar shops were in this town and it was balanced by Banjo Matthews shop. You can see my 68 on video proving my point on winding quick in the " lets hear your exhaust post from a few days ago".
Want a car that will not deliver what was intended ?....run a HEI dist in a 327 or 283 in my opinion. I had one in my 51 ford with a 305...it ran good...never gave any problems....but when you opened the custom built quadrajet up, it moaned....and thats about it...oh, after a while it would finally start to act like a V-8....but it took its own sweet time.
I often just have a irresistable desire to fix things that are not broken. It is a genetic flaw. Looking at my archive engine pics, this may be a no-go as I can't see that HEI distributor fitting with my 1974 air cleaner assembly. And I am not about to change that.
So on to other ways that I can make my Corvette life miserable. D***, I keep looking as the car ran so well last summer.
If you read my post....it says what the yellow wire is for and what the red wire is for. And if you look on top of the plastic cover over the connections...it should read....TACH AND BAT.
Kinda hard to see that oil line, but it's there.
I felt a little breeze outta that #1 sparkplug hole as I wrenched the crank bolt/engine over to TDC. All sparkplugs were removed of course (I ain't that strong!).
