Question
Old Dec 12, 2013 | 11:19 PM
Plasticfreak's Avatar
Plasticfreak
Default Question
[Please explain the vents on the rear deck of my 75 and why someone covered them up with fiberglass or bondo? Thanks in advance!COLOR="Blue"][/COLOR]
Old Dec 12, 2013 | 11:22 PM
MSGT-R's Avatar
MSGT-R
Flow through vents from the interior. They may have leaked (?). They do have a tendancy to gather a lot of leaves and the drains plug up if not maintained.
Old Dec 12, 2013 | 11:28 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Not in a 1975. What they were was the last remnants of the old astro ventilation flow through system that was phased out a few years before 1975. Your vent should just have vents in little recessed rectangles held in by four screws nothing more. They should not have been leaking and I believe were just covered by a previous owner who did not like them.
Old Dec 12, 2013 | 11:47 PM
MSGT-R's Avatar
MSGT-R
Sorry.. I have a 71 with the Astro Ventilation. Didn't know that it was discontinued.
Old Dec 13, 2013 | 05:44 AM
oldgto's Avatar
oldgto
I also have a 71... I glued window screen to the bottom of my vents to keep the leaves and other stuff out of there. Once the vents are installed, you can`t see it unless you`re really looking for it.
I know this won`t make it for a judged car, but just a thought for a "driver".
Old Dec 13, 2013 | 09:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No need to get wrapped up on Astro-Ventilation. It's nothing more than the trade name GM used for the flow through ventilation system used on several car lines in addition to Corvette.
By 75, for a non-AC car, the rear deck vents are probably not functional. They're gone forever beginning with the 76 model year.
Old Dec 13, 2013 | 09:19 AM
Eljay's Avatar
Eljay
I think the script on the windows is pretty cool.
Old Dec 13, 2013 | 10:18 AM
chstitans42
TheCorvetteBen
Old Dec 13, 2013 | 10:40 AM
Easy Mike's Avatar
Easy Mike
Back in the last millennium, I owned three 68 Impalas. They also had the Astro-Ventilation scripts on the doors glasses and the same chrome dash vent ***** as C3s.
Old Dec 13, 2013 | 11:26 AM
GreenDream's Avatar
GreenDream
My 74 still has astro-ventilation.
Old Dec 13, 2013 | 12:59 PM
corbettworks's Avatar
corbettworks
I pretend I have Astro Ventilation in my '77.
Old Dec 13, 2013 | 03:08 PM
Ontario73's Avatar
Ontario73
I have a non A/C 73 with functional astro vents. Believe it or not it works quite well. I'm a smoker (yeah I know) and you can really see it draw the smoke out on the highway.
Old Dec 13, 2013 | 08:26 PM
jnealg's Avatar
jnealg
My 75 non ac has functional astro vents. Well they would be if I fixed the vac line to the actuator.
Old Dec 13, 2013 | 08:51 PM
Plasticfreak
My car has air but I wondered why the po put bondo over them to cover them up? I don't understand
Old Dec 14, 2013 | 06:35 AM
jnealg's Avatar
jnealg
Cleaner look? Like rebadging or shaving handles.
Since it's an ac car you should have the inner cabin ports blocked off. Maybe the po didn't understand this and just saw holes.
Old Dec 14, 2013 | 07:58 AM
oldgto's Avatar
oldgto
To Question
