L48 or L82?
Old Dec 12, 2013 | 11:19 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Default L48 or L82?
I just bought an engine block and heads for a 1974 Corvette (350 CI) and was wondering if there is any markings on the block to tell if it is for an L-48 or L82 car. The VIN derivative wont have the letter that the full VIN would have. It is just the engine block and heads.
Thanks!
Old Dec 13, 2013 | 12:05 AM
Patro46's Avatar
Patro46
Thanks!
Funny you ask. I recently acquired 74 convertible, and went through just that. I was told the engine wasn't original. A little research proved otherwise. So yes, not only can you tell if it's an L-48 or an L-82 and what year, it can also tell whether the transmission that was mated to that motor was a standard or an automatic. I'll do some digging and try to post the link. Congrats on your 74! The bummer to our year is the dismal HP from either the L-48 or the L-82. On the bright side ours was the last year of true duel exhaust and more importantly I can assure you, is the fact ours was the last year to have a fiberglass floorboard. Thank your lucky stars on that one, I assure you!
Old Dec 13, 2013 | 12:11 AM
Mike Ward's Avatar
Mike Ward
Thanks!
Tell us what's stamped on the pad in front of the passenger side cylinder head.
Old Dec 13, 2013 | 12:36 AM
CanadaGrant's Avatar
CanadaGrant
Old Dec 13, 2013 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You should find two stampings on the engine pad. Engine ID and VIN derivitive.
Old Dec 13, 2013 | 09:35 AM
77C34SPD's Avatar
77C34SPD
What size valves? 2 or 4 bolt mains?
Old Dec 13, 2013 | 09:38 AM
pacecar620's Avatar
pacecar620
Simple test: Drop the pan, 2 bolt mains = L48, 4 bolt mains = L82.
Old Dec 13, 2013 | 09:41 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Is engine suffix missing?
If so, check the number of main bolts (L82 has 4-bolt mains) and check the pistons (dished vs. flat tops). Granted, these could have been changed out, but it will give you a better idea.
Old Dec 13, 2013 | 10:06 AM
SSG26K's Avatar
SSG26K
The CLA suffix shows that it is a 350ci 195 hp automatic it is not an L82. It's an L48.
Old Dec 13, 2013 | 10:17 AM
chstitans42
TheCorvetteBen
Well I actually only bought an engine block, heads and intake. I didnt get a whole '74 Corvette this time! Oh and just so you know 1975 also had fiberglass floors in them. 76 was the first yer for metal floors.
Pics will be coming.
If it that easy, then it is an L48 since it had two bolt mains.
Have not checked yet I will this morning.
Old Dec 13, 2013 | 10:44 AM
Easy Mike's Avatar
Easy Mike
Check the pad on the block. Pete's pic shows you what to look for and where to find it. If the engine ID suffix is there, you don't have to pull the pan or the valve covers to identify the engine.
Old Dec 13, 2013 | 02:18 PM
LeMans Pete
Correct. I do not have a '74 L82 (auto or manual shift) engine pad in my library. My purpose was to give the OP a snapshot of what he is looking for. From previous posts, he is very astute corvette enthusiast, so I am sure he knows about the engine pad. But, I don't always like to assume.
Old Dec 13, 2013 | 03:27 PM
chstitans42
TheCorvetteBen
Checked the VIN derivative and there is an S in the VIN meaning L48. Also the block as two bolt mains, so there it is. Thanks for the help guys!
Old Dec 13, 2013 | 04:33 PM
Mike Ward's Avatar
Mike Ward
They all have an S in the VIN derivative, including the big blocks..............
S is for St. Louis assembly plant.
Old Dec 14, 2013 | 10:06 AM
Easy Mike's Avatar
Easy Mike
They all have an S in the VIN derivative, including the big blocks...S is for St. Louis assembly plant.
Yep.
Check the number on the pad beside the VIN derivitive.
Old Dec 14, 2013 | 12:49 PM
chstitans42
TheCorvetteBen
Old Dec 14, 2013 | 01:25 PM
Mike Ward's Avatar
Mike Ward
The 4 before the S in the VIN says it's from a '74 model year car. The engine machine code says it was assembled on August 1st at the Flint MI plant and went into a L48 w/Turbo 400 Corvette.
The VIN indicates it was installed in car S/N 131, probably the second day of production.
To L48 or L82?
Old Dec 14, 2013 | 01:42 PM
LeMans Pete
There you go: CLA is the engine suffix for a L48 automatic.
Old Dec 14, 2013 | 09:56 PM
MakoJoe's Avatar
MakoJoe
Thanks!
Here is site that gives the casting numbers
http://corvettec3.ca/casting.htm#1974_Options
Old Dec 15, 2013 | 11:40 AM
Easy Mike's Avatar
Easy Mike
Bingo. An L-48 for automatic transmission assembled August 1 at Flint. It went into #131 at St. Louis about two weeks later.
