Door Skin Experts
Old Dec 13, 2013 | 08:04 AM
Cavu2u's Avatar
Cavu2u
Default Door Skin Experts
Attempting for the first time at replacing the door skin on this '73 door.
How smooth does the panel have to be? As you can see, the original vinyl has peeled off from the lower forward quarter. Should the existing vinyl be removed first, so as to make a uniform surface for the new skin? If so, how?(Heat gun, etc)
What brand name/type of adhesive is best?
I realize the work/time envolved is more of a pain than paying for a replacement door panel, but want to just DO it and see. Any advice/tips on replacement is appreciated.
Thanks in advance.
Steve
Old Dec 13, 2013 | 09:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Who made your skins? Did they come with installation instructions? If not contact the manufacturer and ask how they should be installed.
Good luck with the installation.
Old Dec 13, 2013 | 10:15 AM
Cavu2u's Avatar
Cavu2u
Thanks for the good wishes.
Don't know who made them, but this is who sold them:
Old Dec 13, 2013 | 09:42 PM
Cavu2u's Avatar
Cavu2u
Default Old Skin Removal
Using a heat gun to warm the section to be peeled first, the skin pulls off much easier.
This open section was there at the production plant. The adhesive used was brushed on.
Also, this skin started out as black.
Gettin' there. Slow but sure. I've found that just a film of the foam comes off with the skin if you use heat and go slow.
Old Dec 14, 2013 | 08:28 AM
lvmyvt76's Avatar
lvmyvt76
would it have been better to buy new door panels, that will take less time and probably look better than what you are having to do???
Old Dec 14, 2013 | 08:55 AM
Roco71's Avatar
Roco71
Keep us posted on the process. I know of one other member doing this he made the comment that it was not as easy as he had hoped. Good chance that he will chime in.
Old Dec 14, 2013 | 12:18 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The skins are designed to go over the old vinyl...
You're going to have one heck of a time installing skins now. Is it possible! Anything is possible, but boy oh boy what a job. Any imperfection under the new vinyl will usually shrink and show when you are finished with the installation. We never suggest door panel skins to customers, and in my opinion they should never be sold. Bare door panels and transferring the old trim is always the cheapest way out.
In the old days, when all we could get was a skin we had no choice… and I hated this job.
Before we installed the skins, all the cracks in the old panels had to be repaired. The trick was to cut all the cracks out and then fill the void area with silicone using a very special, important secret ninja tool.... Ice cube's.... (With the ice cube you can spread the silicone smooth).
I too am curious as to how this turns as well.. You may want to return the skins and get the panels… IMHO.
Willcox
Old Dec 15, 2013 | 06:46 AM
Cavu2u's Avatar
Cavu2u
Willcox
"IMHO."
To Door Skin Experts
