Engine Noise
Dec 13, 2013 | 03:13 PM
Engine Noise
Just started my 73 Vette. My brother had and It hasn't started four a year finally got a new battery for it. It started right up but it was very loud. It sounded like clanking noise. Any suggestions on what i should look for before i tear it apart?
Dec 13, 2013 | 03:46 PM
Cruise-In II Veteran
Define "clanking." Did you check the oil level before you lit it up?
Dec 13, 2013 | 03:50 PM
engine noise
Checked the oil before starting. Almost like a bang. Probably should take out spark plugs and give them a look at. Also maybe water pump?
Dec 13, 2013 | 04:01 PM
Take a video to.give us an idea. . Clanking or big bang could be a hundred things. If you hadn't started in over a year it could have been just a loud back fire or bad fuel in the system not firing right causing nkocking.. does it sound like a metal on metal bang or what?
Dec 13, 2013 | 04:29 PM
engine noise
Sounds more of a metal on metal sound.
Dec 13, 2013 | 04:37 PM
Maybe a cat hung in the fan shroud.
Thumping as it spins around
Dec 13, 2013 | 05:16 PM
engine noise
Or maybe some mice in there thumping around.
Dec 13, 2013 | 05:23 PM
If it's a manual transmission car, cover plate on bellhousing can give you fits when it grinds against the flywheel
Dec 13, 2013 | 05:29 PM
engine noise
Well automatic trans but i just had it towed here. I dont know going to get my son to video it tomorrow. Dosnt sound like valves it just clanking
Dec 13, 2013 | 06:09 PM
Quote:
Originally Posted by
LS4 PILOT
What an awful fate for a fan shroud.
Dec 13, 2013 | 06:20 PM
Dec 13, 2013 | 06:25 PM
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Check under your valve covers. Rocker arm maybe loose. Had that happen on my 71 350 corvette.
Dec 13, 2013 | 06:28 PM
engine noise
Give that a look at thanks
