SNAP! Spring I think...
Terry
I agree with you that it doesn't take long to get a tiered leg when in heavy traffic.
This was long before cell phones. No sooner did I get off the ramp and coasted in neutral, when a good Samaritan in a truck pulled up. He hooked up, the valance was already broken, and towed me home.
What followed next was a series of poor repairs by the local "corvette expert" (Ron's Speed & Sport). That was the beginning of the end of my love for my 73 and I stored the car away for nearly 20 years.
Love has been rekindled.
Here's a pic of the clutch pedal return spring from my '72 car. Is this the one that you can see broken?
One end attaches to the firewall here, next to the steering column, correct?
The other spring end, in the smaller hole of the z-bar(near side by stud & nut, in this image):
I expect that mechanically, my pedals aren't that much different than yours (they're the same). Under the dash, I don't recall a spring connected to the clutch rod, so that's a plus. BTW, I used a Steeroids clutch linkage kit. That may be why the linkage here may look different than OEM. Visible linkage to the switch is part of the neutral safety interlock.
If the anti-rattle springs are intact, I'd expect it's just a matter of replacing the spring attached to the firewall flange, no?
Let us know if this offers any help. Good luck.
The situation demands you take a closer look at what's up there. Something similar but worse happened to me. While driving around I pushed the clutch pedal in and it stayed there. Made it home OK (an adventure to be sure in timing red lights and controlling RPM to shift) to discover that the cotter pin had worn off and the pedal slipped off the post.
As you say "a clutch pedal is always a good thing to have with a manual transmission".
Thanks to you too Ignatz - the situation that you describe is exactly what I'm trying to avoid.
As I recall, that orange spring is primarily to keep the brake lever up. Those shaft components are from a bushing rebuild kit that I ordered and installed.
Those parts can be seen when you click on the picture in this CC link:
http://www.parts123.com/parts123/yb....5Z50000050G~~~
I don't think the orange spring influences the position of the clutch arm at all. The arm position is adjusted more from the linkage all the way to the fork and assisted up with that spring at the firewall flange. Hope that you get it fixed to your satisfaction.
