Washer fluid pump
Old Dec 21, 2013 | 07:47 PM
tk1616's Avatar
tk1616
7th Gear
Default Washer fluid pump
Hey everybody. When I push my windshield washer on, you can hear the pump run, but it just trickles at wipers. I pulled the lines and they are clear. At the "T", I have good, fipull hose flow, but there is not a lot of pressure. It has about a 4" arc. Should it be coming out harder? Think the pump is bad?
Old Dec 21, 2013 | 08:12 PM
LB66383's Avatar
LB66383
Remove the hoses from the pump, then remove the screws to remove the pump cover. It's my understanding there's a diaphragm in it that pulls the water in a pushes it out. If the diaphragm is cracked, that'll reduce the pressure.
