Question about a 1969 Stingray Anomaly
Old Dec 30, 2013 | 08:54 PM
Phillydog's Avatar
Phillydog
Having a beer is never a bad option.
Old Dec 31, 2013 | 06:55 AM
oldschoolvette's Avatar
oldschoolvette
Originally Posted by Ratfinkharley
Beer does make you smarter; it made Bud wiser.
to the OP Good luck on your quest to find the truth
One thing I do know is that speaking in certainties when it comes to cars from that era is dangerous. Dealers changed things before they sold a car and special order stuff was not that uncommon.
Check all the tags and see what is what.
Odds are its not a factory original but you never know and this kind of stuff is part of the fun.
Old Dec 31, 2013 | 10:11 AM
Mike Ward's Avatar
Mike Ward
There's no known examples of an L46 w/auto being built. There is no assigned engine code for the combo so there would be no way for the Flint plant to have built an engine suitable for an auto box.
There must have been a hundred if not a thousand people come though this site over the years thinking they might have a one-off 'special order' car. To my knowledge, not one has turned out to be genuine. Contrary to legend, 'special orders' were extremely rare and very narrow in spectrum. No special engines, no special transmission, no special combos.
In this case, the only thing that points to L46 so far is the data plate on the console and the valve covers.
Old Dec 31, 2013 | 01:56 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Beer..mmm
Philly, Take some pics of the engine pad (not the casting number) and post them. That should clear this up. Happy New Year!
Old Dec 31, 2013 | 06:53 PM
Phillydog's Avatar
Phillydog
Originally Posted by avalonjohn
Beer..mmm
Will do, thanks to all of you very knowledgeable vette folks.
I will try and post some pics tomorrow, I've already had several high alcohol beers.....
Happy New Year's to all.
Phillydog
Old Dec 31, 2013 | 11:30 PM
dmaxx3500's Avatar
dmaxx3500
on the ''left'' drivers side of the trans at the pan rail,just above the pan rail bolt holes,there is a stamped vin#
Old Jan 1, 2014 | 10:27 AM
Phillydog's Avatar
Phillydog
Thank you I will take a look for the number.
Regards,
Phillydog
Old Jan 6, 2014 | 07:37 PM
Phillydog's Avatar
Phillydog
Regards,
Phillydog
I found the following Casting Code on my engine behind the cylinder block on the driver's side:
42GM
3970010
I also found the following Date Code on my engine behind the cylinder block on the passenger's side: K 14 9 This code might not be completely correct because is was very hard to read.
I could not find the engine VIN pad at the front of the engine block on the passenger side.
I have attached a couple of engine pics. Any additional info anyone can provide would be appreciated.Name:  SDC13708.jpg
Old Jan 6, 2014 | 08:43 PM
Mike Ward's Avatar
Mike Ward
42GM
3970010
3970010 is the casting number. K149 is the casting date which translates as November 14th in a year that ends with 9. As these blocks were cast over more than a 10 year time span, the year could be 1969 or 1979.
The stamp pad is visible in this pic if one first looks at the two vertical steel fuel lines leading to/from the fuel filter, then looks just slightly across towards the upper rad hose. It's a square shiny pad directly behind the R/H water pump leg.
The appearance of this pad being square is typical of 1979 engine blocks. A 1969 block would have a rectangular appearance.
Old Jan 7, 2014 | 07:21 PM
Phillydog's Avatar
Phillydog
Thanks Mike for this info! I'll look for the pad where you described.
Regards,
Fred
Old Jan 7, 2014 | 09:13 PM
RobRace10's Avatar
RobRace10
Regards,
Fred
Here is where to look as Mike said. It's on the surface facing towards the passenger side.
Old Jan 9, 2014 | 08:33 PM
Phillydog's Avatar
Phillydog
Rob/Mike,
Thank you for your help. Unfortunately I looked on that pad and found no markings. I have attached a close up pic of that location. If I am still looking in the wrong place please let me know. Clearly I am a real novice at this.
Thanks,
Phillydog
Old Jan 9, 2014 | 08:44 PM
  #33
Mike Ward's Avatar
Mike Ward
You're close. The above photo is upside down and you've taken a picture of the side of the stamp pad instead of the top. It looks like somebody has already scraped off some paint .
Old Jan 9, 2014 | 09:11 PM
  #34
Phillydog's Avatar
Phillydog
Hi Mike,
Thanks for the feedback. I just examined the part of that pad where you can see the black on the surface with a magnifying glass and still could not find any markings. Am I still looking at the wrong location?
Old Jan 9, 2014 | 10:00 PM
  #35
Mike Ward's Avatar
Mike Ward
Hi Mike,
It's probably been decked. Post a pic of it anyway.
Old Jan 10, 2014 | 07:11 AM
  #36
Phillydog's Avatar
Phillydog
Hi Mike, I'll try & get a good pic 2 post. What does "decked" mean? Do u have ny other ideas of places 2 look on the engine? This has been quite an education 4 me. Thanks Fred
Old Jan 10, 2014 | 08:27 AM
  #37
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...What does "decked" mean?...
Stampings removed as a result of machining the block surfaces (called "decking the block").
To Question about a 1969 Stingray Anomaly
Old Jan 10, 2014 | 10:12 AM
  #38
Phillydog's Avatar
Phillydog
Oh okay that would make sense as that surface felt much smoother than the other parts of that pad. I'll still try & get a good pic of that pad surface 2 post. Thank you 4 all of ur great insight....same 2 all others who posted on my thread.
Regards,
Fred
Old Jan 10, 2014 | 10:59 AM
  #39
LPE385's Avatar
LPE385
Is it me or does the last picture where is shows the pad look small like a late 70's pad, maybe an over the counter motor. It may be the angle but the pad looks small again like the later motors 78-80?
Old Jan 10, 2014 | 11:17 AM
  #40
Mike Ward's Avatar
Mike Ward
see post #29
